got 1 mini i-pod just bought another will they work fine on same PC?
Discussion in 'Headphones, Earphones & Portable Music' started by w3dal, Jan 7, 2005.
  1. w3dal
    w3dal
    Aug 4, 2002
    4,919
    Chelmsford, Essex
    +543
    Hi All,
    Bought my other half a mini-pod for Christmas and was so impressed with it i have just ordered one for me.
    Now is it possible to have 2 ipods connected to the same PC using different Profiles.
    The software was originally installed on Sallys Profile and although i have i-tunes loaded into my profile (did this on its own) i remember adding the serial code and i assume i would do that on mine aswell.
    Do i need to install the software again from the CD for my ipod or should it already be on there from doing the install on Sallys profile.
    Any help would be much apprecated as i wanna get this hooked up ASAP
    Dal
  2. ipodstudio
    ipodstudio
    We just covered that very question here.. :smashin: Short answer: yes you can, manual sync.
  3. w3dal
    w3dal
    Aug 4, 2002
    4,919
    Chelmsford, Essex
    +543
    Thanks for the link. As im new to the Ipod schene i shall join that board when i get home tonight.
    Thanks mate
    Dal
  4. ipodstudio
    ipodstudio
    No worries, glad to help.. ;)
  5. w3dal
    w3dal
    Aug 4, 2002
    4,919
    Chelmsford, Essex
    +543
    the only thing i would say is that in that post, It seems that guy and his wife are using the same profile and itunes for there i pods.
    I want to use my profile and itunes not my girlfriends i tunes and profile.
    if that makes sense.
    Dal
  6. ipodstudio
    ipodstudio
    Just add a second user and profile to iTunes...
  7. w3dal
    w3dal
    Aug 4, 2002
    4,919
    Chelmsford, Essex
    +543
    Ill give it a try.
    Dal
