Gordon/chris /roland/anybody.
Discussion in 'Projectors, Screens & Video Processors' started by MUD, Jan 20, 2002.
  1. MUD
    MUD
    HI
    SINCE I got no replys I will ask again MY sim 420 packed up on friday night. THERE is power on when I switch it on the fan start up but tubes dont come on I have it from new IT is only four mts with about 250 hrs use. I have contacted the firm I bought it from. They will call out to me next. WHAT I wanted to know has anybody else had trouble with this model. I know it is still under guarntee. but it looks it back to the factory. THANKS MUD.:mad: :mad: :mad:
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,055
    I have never sold this model. I've also not had this problme with nay of the SIM2 models I have sold.
    Sorry I have no solution.
    Gordon
  3. uncle eric
    uncle eric
    Mud,
    The Seleco models are generally very reliable.
    To avoid burn in, Barco's have a pause button that allow the tubes to be off while the PJ is working. Does your 420 have anything like that which may be on without you knowing. Just a thought.
    Anybody.
  4. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    Mud,
    Uncle Eric has hit on the first thing I'd try - MUTE. This gives exactly the symptom you describe.
    After that, I would look at whether one of the small plug in circuit boards has come loose due to vibration. This sometimes happens when the projector is mounted below a bedroom or when there is a particular bass frequency that causes sympathetic resonance in the projector chassis. Either way, the cure is simple. Just push the cards back in place and then secure with a small blob of silicon.
    As a side note, when I was with Owl we sold some 400's to a simulator manufacturer. They were mounted in the ride capsule so were subjected to the same vibrations and shocks as the passengers. We siliconed just about everything and they worked great.
    Speak to your dealer about checking the seating of the protection card and the power supply daughter boards.
    Regards
  5. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Is the EHT crackling when it starts up?
    But to back up the other reseat the boards.
    and why do projectors only fail in friday night?
  6. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    :blush: :blush: :blush:
    I have not had this problem before.
  7. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,055
    We'll leave it to forum members to work out whether this is an inditment on Rolands sexual prowess or Barco projectors......
    Gordon
  8. MUD
    MUD
    THANKS LADS
    FOR your replys I will let you know tomorrow.
    ROLAND I looked under the bonnet and you guest it **** no water in the rad do barco have rads or are just full off sh
    HA HA MUD.
  9. Paul D
    Paul D
    Dec 27, 2000
    2,781
    Manchester
    +550
    This is commonly known as the "rhythm" method! :D ;)
  10. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Have you established the fault yet?
    I'm off to bed and she's watching a film this can't be why I got into projectors.:clown:
  11. Steve at NMI
    Steve at NMI
    Roland
    Move the projector into the bedroom.
    It will solve all the problems.
  12. MUD
    MUD
    HI
    SORRY for been late but was watching the MATCH.
    anyhow today ADreen came to see what was the problem was and found the chip for verical on the Deflection Panel was gone. HE then went out to his VAN and came in with a brand NEW 420 in which he then instaled. how is that for SERVICE. just in time for the you guest it MATCH. HOWs that for service for me ten out ten. BY the way I have my 420 floor mounted in a unit I made fan noise not worth talking about. anyhow thanks for all your replys. I can sleep tonight.
    MUD.:D :D :D :D :D :D :D
