Google Home with Hive/British Gas Smart Linked Thermostat
Discussion in 'Smart Home, Climate Control & Security Forum' started by itm, Dec 26, 2017.
    1. itm
      itm
      Dec 21, 2008
      382
      +11
      I've got one of the older British Gas Smart Linked Thermostats - installed 5 years ago and migrated to the Hive service. It doesn't seem to be supported by IFTTT or Google Home at the moment. Does anyone know of a way of controlling one of these thermostats with Google Home?
    2. chriszzzzzz
      chriszzzzzz
      Jun 19, 2005
      1,099
      Coventry
      +83
      I don't have that system, does the current Hive app control your heating or do you still use the original phone app?
      It's the Apps that GH actually controls, If you still use the old app then I doubt you'll get it to work. It looks like they may have changed to Hive, but kept the old system working without merging them.
    3. itm
      itm
      Dec 21, 2008
      382
      +11
      The Hive app controls my heating. I don't see any Google Home support for Hive heating controls.
    4. Jamie
      Jamie
      Jun 27, 2007
      5,195
      2
      Harrogate
      +1,332
      I don't have either Hive or the older system but Hive is definitely listed in the home app.
      Tap the hamburger menu at the top left, choose home control and click the plus button. Hive is listed among all the other options.
    5. itm
      itm
      Dec 21, 2008
      382
      +11
      Good grief I can't believe I didn't find that before - many thanks!
    6. Jamie
      Jamie
      Jun 27, 2007
      5,195
      2
      Harrogate
      +1,332
      You're welcome, does it work though? that's the big question.
    7. itm
      itm
      Dec 21, 2008
      382
      +11
      Hmmm...almost...while the thermostat responds to commands (e.g. set thermostat to 7), the thermostat reverts to its original value a minute later! (presumably reverting to the schedule)
    8. itm
      itm
      Dec 21, 2008
      382
      +11
      I've just been on a chat with Google support and they say "it is yet to be supported by Google Home". "For Hive products , it is compatible to Lights Plugs and Switches" :0(
    9. chriszzzzzz
      chriszzzzzz
      Jun 19, 2005
      1,099
      Coventry
      +83
    10. itm
      itm
      Dec 21, 2008
      382
      +11
      I did try using IFTTT but it doesn't seem to recognise my thermostat. When I get to the "That" definition I am asked to specify which thermostat. The dropdown list just says "Options Unavailable" - I'm not able to enter a valid value in that field. I registered my Hive account with IFTTT so in theory it should be aware of my thermostat.
