Goodmans TVC201T - clicking
F
fragglemoo
I've recently moved my Goodmans TVC201T down stairs and when I switched it back on it just clicks and the standby light briefly flashes. :confused:
Does anyone have any ideas what this means - other than it doesn't work ;)
Thanks.
JayCee
Outstanding Member
Thanks.
Were you in the habit of not switching the set off at the mains switch but just switching it to standby?
F
fragglemoo
I believe it was on standby, my partner then switched it off and moved it.
JayCee
Outstanding Member
If you were in the habit of just switching it to standby everytime and never switched it off from the mains...........and, unless it was dropped or knocked when it was moved the most likely cause of the fault is probably a capacitor in the power supply section of the set.
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
