Goodmans question
Discussion in 'General TV Discussions Forum' started by spiritualized, Jun 28, 2002.
  1. spiritualized
    spiritualized
    Dear all,
    I am after a bit of help : Does the Goodmans W280NS have the capability of receiving SECAM transmissions ?
    I hope to be able to watch French channels through my satellite system.
    Thx a million.
    Olivier
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Don't know the specifics of that model but you should be able to watch the broadcasts in black and white at the very least as the only difference between SECAM and PAL is the colour encoding. If your satellite receiver has RGB SCART output and the TV has RGB SCART input then you should be able to watch in glorious colour, although recordings will still be in black and white unless you have a multi-system VCR as VCRs only record composite video/s-video signals. Hope this helps.
