Goodmans plasma 42in (GTV42P3) help please
Discussion in 'Plasma TVs' started by ritchie39, Dec 29, 2004.
  1. ritchie39
    ritchie39
    Rite i got my self a plasma 42 in tv last week and i have just noticed a line down the right hand side on the screen about 9 in's in, and before i send it back im just curious to what would cause it and what it could be. any help would be gratefulll ?
    any 1?
    i have tryed different scart cables but still the same.
    there is nothing near to it to interfere with it
    im using a dvd,sky system ,and a ps2 but only 1 scart cable comming of the tv to a 3 way splitter skart boxwhere the other items are connected to
    and yes it is rg, you can only see the line when it is on a light picture and the line is vertical
    hope that helps a little
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    this often happens on cheap plasmas, not sure why (cheap electronics) Some TINY plasma owners have had similar issues.....get it swapped....... otherwise are you happpywith PQ? Is this the one that is £999 at argos?
  3. ritchie39
    ritchie39
    yes this is the one from argos, rest of the picture is brilliant and the sound is ok aswell. i mean u pay for what you get but *** its only like a week old
  4. Peabo
    Peabo
    Had the same probelm on my Samsung: line down the screen after one week. I got a refund after it happened again on the replacement Samsung which they sent.
  5. Ferg 36
    Ferg 36
    Nov 14, 2004
    3
    I had the same problem with the Goodmans Plasma.
    Argos sent a replacement but that one had a loud buzzing from the speakers. I contacted Goodmans and they said it required an upgrade and offered to send an engineer to my house.
    I gave up and returned it to Argos and bought an LG Plasma from Comet instead
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  7. ritchie39
    ritchie39
    chears ppl :smashin:
  8. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    I saw the PW6 for 1299.95 in Richersounds yesterday
