Goodmans LD2601 26" LCD ...any good ?
Discussion in 'LCD & LED LCD TVs' started by Nikral, Dec 30, 2004.
  1. Nikral
    Nikral
    Dec 29, 2004
    2
    Hi all,
    'Newbie' here so please bare with me .
    I have seen this 26" LCD screen for sale in a high street store for £699 .
    Here
    It seems to only be available at this store alone , so the price cannot be compared elsewhere .
    The make is GOODMANS and the model is LD2601 . It seems to be pretty good spec wise with 1280x768 resolution and 600 for both brightness and contrast.There are RGB scart connections and component inputs ( although spec sheet says 'NO' to component ! ) along with DVI , a PC input and a built in tuner with teletext . It has progressive scan , PIP and is wall mountable .All or most of the things I needed/wanted seem to be included on this LCD, but is there a catch ?
    I have seen this LCD in store and the picture looked pretty good from a dvd , even though it was being fed through co-ax . While playing with the remote I found BBC 1 etc and saw as good a picture as you will in these places . The video signal can only be improved and therefore a better picture will be seen.....right ??
    It all seems a good deal but does anyone have any reservations or concerns about the set. I would be very grateful for any advice because as I said before I'm new to this and very fearful of an expensive mistake .
    cheers
    Nikral
    *Sorry .... just found same questions in previously posted thread*
    My questions are currently being answered !!!!!!!!!
    Thanks .
  2. Spooksta
    Spooksta
    Nov 7, 2000
    2,677
    Planet Earth
    +296
