Goodmans HEC17 Home Theatre Kit
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Bales1983, Jun 15, 2004.
  1. Bales1983
    Bales1983
    Just bought the above mentioned all in one package but the dvd player is Region 2, anyone know how to multiregion this player?? Ive searched around the net but nothing so far :confused:
    Id be very happy with any help.
    Lee
  2. NickE27
    NickE27
    Hi, I also have the HEC17 Home Cinema System. I've seen a mulitregion thing for it before but i can't rememebr where. There is definately one about though. Also, have you noticed quite a loud background hiss when using dolby digital 5.1 with this system? I have with mine and I'm not sure if it's just mine or all of them. When using pro logic 2 it is not a problem.
    Thanks,
    Nick
  3. NickE27
    NickE27
    I found the hack again. I haven't tried it yet though so I'm not sure if it will actually work:
    To convert this player to Multi-Region
    1. Press the Open button on your remote control to open the drive tray
    2. Press the Setup button on your remote control
    3. Press the Next button on your remote control
    4. Press the Previous button on your remote control
    5. Press the Next button on your remote control
    6. Press the Previous button on your remote control
    7. A code should appear on the top left hand corner of the onscreen display
    8. Using the Left and Right direction buttons on your remote control, change the code to VER 1 for region 1 playback, VER 2 for region 2, and so on, or VER 255 for multi-region playback
    9. press setup to finish
    NB: You may need to use the up and down buttons to select the region option before you change it
  4. Bales1983
    Bales1983
    Hi Nick,
    Ive successfully multi regioned my dvd now along with ensuring mp3 and vcd playback!, Yes the hiss is there, its also there slightly on the D Prologic but nowhere near as bad, Ive come to accept its part of buying a cheap budget system!
    Lee
  5. Nape Dog
    Nape Dog
    Mar 2, 2006
    1,768
    +80
