Goodmans GDVD67LCD portable
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by michaelm, Jul 11, 2004.
  1. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    I've one for the Goodmans portable GDVD67LCD.
    [Also works with the Acoustic Solutions DVD421 and the Mustek DVD-V56L.]
    Note: If steps 2 - 5 have no effect, you may need to press the equivalent buttons on the player itself.
    1. Press the Setup button on your remote control.
    2. Press the Next (>>|) button on your remote control.
    3. Press the Previous (|<<) button on your remote control.
    4. Press the Next button on your remote control.
    5. Press the Previous button on your remote control.
    6. A code should appear on the onscreen display.
    7. Using the direction (>>/<<) buttons on your remote control, change the code to VER 1 for region 1 playback, VER 2 for region 2, and so on, or VER 255 for multi-region playback.
    Press down (stop) once change the code to VER 3001 to enable parental controls, or VER 3000 to disable these controls.
    Press the Down key once again and change the code to VER 5001 to disable VCD/SVCD playback, or VER 5000 to enable this feature.
    8. Press the Setup button on your remote control.
