Goodmans GDVD 126
Discussion in 'Blu-ray & DVD Players & Recorders' started by Starburst, Aug 2, 2001.
  1. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    A friend of mine was given a Goodmans GDVD 126, anyone know if there is a remote hack, similar to the one that can be used on the 124?<br />If not, how about which player the Goodmans is based on?
    Any help appreciated, Mike
  2. mamaflump
    mamaflump
    Hi there,<br />Sorry i don't have the hacking code your looking for..but maybe you could help me..do you have the hacking code for the gdvd124?<br />please either e-mail me or leave a message..thanx
  3. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Try this-
    power on (leave tray closed)<br />on the remote press 7-7 then enter,<br />set region to 13 (all regions)<br />press set up to save.
  4. mamaflump
    mamaflump
    Thanx for trying but it didn't work!.Any other suggestions please?
  5. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    1. Open the drive tray <br />2. Press the buttons 7 and 4 on your remote control in order, one at a time<br />Note: If the above doesn't work, you may have to enter the digits 7 and 7 instead <br />3. A hidden menu will appear where you can scroll down to Country Code and using the Select button, choose any region between 1 and 6, or select 13 for region free. <br />4. Press Return to exit the menu
    <br />Taken from the dvd reviewer site.
  6. mamaflump
    mamaflump
    sorry starburst but none of those worked either..is it possible to let me know the site you got the information from??<br />thanx
  7. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    dvd.reviewer.co.uk
    I also got that same method from my friend with the 126.
