goodmans freesat+ gfsdtr320hd
finellie
can any one help i have a goodmans freesat+ gfsdtr320hd and a polaroid full hd lcd tv when i connect my freesat to tv via hdmi lead theres picture but no sound it comes through as a dvi the tv has 3 hdmi ports i have tried all 3 with different hdmi leads the same 3 ports and the same leads work fine with dvd player so nothing wrong with ports on tv, freesat works through scart but want it through hdmi lead obviously for hd can anyone help p:lease:please :(
logiciel
Welcome to the forum.
I don't know why the audio isn't working by HDMI but have you tried connecting it some other way, with the video still by HDMI?
grahamlthompson
Try turning up the box volume using it's own remote.
finellie
volume is up on freesat box, have connected box via scart that works connected box back to other tv that works its streaming through as a dvi i have a opctical on back of freesat but not tv and have rca on tv but not freesat its strange 1 thx
finellie
when i switch tv to hdmi source to watch sat the source changes to dvi for some reason been in both tv and sat put tv on hdmi port cant find nothing in sat menu about hdmi pictures going through so something is there sorry there is in sat menu it is on hdmi output 1080i
grahamlthompson
Completely lost, DVI and HDMI are the same video connections. DVI is a different plug and with TV's needs a seperate audio cable. Are you connecting to a DVI socket on the TV
DVI Guide - Connectors and Cables Explained | Tips | Support | LINDY UK
or a HDMI socket ?
HDMI - Wikipedia, the free encyclopedia
Is the cable you are using HDMI to HDMI or HDMI to DVI ?
finellie
the lead is hdmi to hdmi, i have put hdmi lead in back of sat connected to hdmi on tv i just don't understand that the tv is saying on screen that its a dvi, im confused too with tv being 3d i also bought a hdmi 3d compatible and tried that didn't work and have tried all 3 hdmi ports on tv i put tv on hdmi in menu also sat menu hdmi out 1080i just dont know what is happening thought it would just work with hdmi lead thx again
grahamlthompson
You originally said you can get a picture but no audio. Is that by HDMI ?. If so does changing from a HD to a SD channel make any difference ?
finellie
yes thats by hmdi, im not really up on these things how do i check that, if u mean getting sound + picture by any other means rather than hdmi lead yes they are working
grahamlthompson
Did you try watching both a HD channel and an SD one when you had video using HDMI ?. They use a different sound compression system.
finellie
you're losing me i have just tried bbc one hd no sound and normal bbc still the same if thats what you meant through hdmi sorry if im not getting it
grahamlthompson
Yes that's what I meant. It was possible the TV had a problem with Dolby Digital audio that you get on HD channels.
Can you make a recording and then try the box on another TV with hdmi in (perhaps a friends) to see if you can hear the recording ? You may have a faulty box.
finellie
thx will give that a go later i will come back later when i get an answer thx for all your help, stephanie
kevkbuk
I've never seen a TV have a DVI mode when they are HDMI inputs but it does rather suggest it could be using another input for the sound....
Would also be worth trying the Grundig on another TV via HDMI if possible as they not known for their quality and reliability. :D
logiciel
You could take the audio from the Freesat machine by its Scart Out socket, using a converter to phono sockets, and connect those to the TV's equivalent sockets.
grahamlthompson
How would you be able to listen while the appropriate hdmi input was selected :confused:
TV's aren't like AV amps you normally can't elect to take audio from 1 input and video from another.
cyclic
finellie,
On goodman,
In menu -> settings -> hdmi
you could try toggling the audio setting
(hdmi/spdif/sterodownmix)
grahamlthompson
finellie,
On goodman,
Which will only affect the HD channels, that's why I asked about any difference between HD and SD. SD channels already output lpcm stereo.
cyclic
Graham,
I understand your HD/SD issue, compression codecs and note the test results that the OP posted.
My comments instead relate to the issue of how things are connected and the resultant necessary audio routing.
I quote:
"HDMI Audio.
If your Digital TV Recorder is connected to your surround sound system using HDMI, choose the Dolby Digital setting.
If your Digital TV Recorder is connected to your surround sound system using SPDIF or Optical connections use the Stereo Downmix setting"
I am suggesting that the setting may be set to route via SPDIF and that in this implementation, the wording implies that this will stop audio being routed to the HDMI.
I would assume that the routeing would be constant for HD & SD even if they had different audio codecs.
Hence I would suggest that "finellie" tries toggling the setting.
It may help - it may not...
logiciel
Correst but this TV is not normal, as it's claiming to be getting DVI video, and as you and kevkbuk have already said that would need a separate audio input.
grahamlthompson
Graham,
I quote:
"HDMI Audio.
The advice is pure rubbish. S/pdif is perfectly capable of Ac3 5.1 (or even the superior DTS 5.1 codec), provided the amplifier has the required decoder (ac3 or dts)
My foxsat uses S/Pdif to deliver full surround when available to my Denon amp. You can't surely be suggesting that a Harvard based box, poor as they are doesn't do the same. If so the digital audio S/Pdif output would be pointless. You might just as well use an analogue stereo output.
For a SD channel there is nothing to downmix, its already pcm stereo.
SD transmissions have mp2 (mpeg1 layer 2) audio in the transmission, the box outputs lpcm stereo from the audio decoder (the same as you get from a CD player). Basically the one digital audio standard that most anything will work with.
HD satellite transmissions use Dolby Digital (ac3) either 2.0 (stereo) or 5.1 surround. (not so for Freeview-HD which use aac audio)
Selecting the downmix option converts these to lpcm stereo (2.0), exactly the same as you get from a SD channel.
If SD channels produce no audio then selecting the option won't change what the box outputs in any way over any of it's digital audio outputs (s/pdif or hdmi).
The option is designed to allow those with amplifiers without Dolby Digital decoding to use the digital audio outputs with channels using Dolby Digital audio.
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
Latest News
Philips unveils A7507 TWS headphones and new rugged outdoor speakers
  • By Andy Bassett
  • Published
Philips FB1 soundbar will use Fidelio wireless platform
  • By Andy Bassett
  • Published
Philips announces OLED807 and 8807 The One TVs for 2022
  • By Andy Bassett
  • Published
Lenco launches 400 series turntable and speaker combo
  • By Andy Bassett
  • Published
AVForums Podcast: 26th January 2022
  • By Phil Hinton
  • Published
