Goodmans 32" (V81) HD Ready - £349.99 - is it any good?
ChrisGgr
For 405£ the Toshiba 32C3030 is a beter option.Its from ED with 10% discount
blondends
Thanks for the advice - only problem is that I can not find that TV on empire direct. Do you have a link?
Cheers !
ChrisGgr
Ohhh no!!!It must have been run out of stock!!!Crima it was the best you could find.Anyway can you stretch up to 450£ or at least at 420£?
blondends
Umm - I could at a stretch. But now I know I could have had it for £405 I probably wouldn't pay that.
How do you get the extra 10% off at ED?
AHhhh !! I hate this, looking for a TV and commiting is giving me a headache!!
Thanks for the help though...
Chris
blondends
Right - I called ED and they have 160 on order and hope to have them delivered in 2-3 weeks.
Do you really think that it is worth the wait?
Will the Goodmans that I found really be that bad?
Also, how do you get that 10% off with ED? was it a code?
Thanks,
Chris
ChrisGgr
The 10% is possible via code.But when the stock arrives the 10% off will have expired.
nitro23456
I would go for the Toshiba if you can stretch. You really do get what you pay for with LCD TV and it is just impossible to get anything good in a 32 inch for less than £450 and really you need to spending £500+
I have found the Toshiba for £425 at pixmania using the code 'awin070902' http://www.pixmania.co.uk/uk/uk/542...30d-regza-lcd-screen.html?srcid=369&srcid=369
I have a Panasonic tx32lxd70 so I can highly reccomend that but this is around £600, if you could compromise on size down to 26 inchs perhaps you could go for the panasonic 26lxd70.
Unfortunately you are going to have to compromise in one way or another..... maybe on price, size or quality.
blondends
ChrisGgr
Is it so hard to give 425£?
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
