Goodman GLCD27WDVBT - Wall mountable???
Discussion in 'Home Cinema Buying & Building' started by mr smythe, Sep 13, 2007.
  1. mr smythe
    mr smythe
    Apr 28, 2006
    26
    wigan
    Just bought a 27" Goodmans GLCD27WDVBT off ebay, wanted a cheap TV for the kitchen. Looking at the back panel, there are holes in the plastic for bolting on a bracket fitting but theres no actual metal screw thread in the holes. Does anyone know if this TV is supposed to be wall mountable? Also, if it is and if the threads are missing is it poss to remove the back panel and feed some bolts through the holes and secure the braket plate with nuts and washers either on the outside or inside? Any advice greatly appreciated
