Goodbye PT-AX200E, it's time to move on ...
Discussion in 'Projectors, Screens & Video Processors' started by bigal202, Jan 10, 2012.
  1. bigal202
    bigal202
    Nov 28, 2006
    24
    Hi everyone,
    Sadly after 5 years I have had to say goodbye to my trusted Panasonic PT-AX200E. I am looking for a replacement projector and looking for the same outstanding quality and value for money that the AX200E represented back in 2007.
    My budget is limited to £900-£1200, but I will stretch to £1200-1400 for a projector that represents truly outstanding value for money.
    Features that I'm looking for are:
    - Lens Shift & Digital Keystone Correction (Projector may be slightly offset)
    - min 2000 lumens
    - quiet
    - 1080p
    - Projection throw: 76inch screen from 3-5 metres
    - 3D (only if not gimmicky)
    Many thanks for your suggestions.
    Al
  2. kbfern
    kbfern
    Aug 17, 2002
    17,903
    Wolverhampton
    +6,057
    You won't get lens shift and 3D at that price range you would need to go double the budget.
    Your best bet will be an Epson TW3200 for £900 this will give a huge boost in performance on the AX200.It is just short on lumen at 1800, the TW3600 has 2000 lumen but is a couple of hundred more and I doubt you would see any difference.
  3. bigal202
    bigal202
    Nov 28, 2006
    24
    Thank you for that, I will check up on those models and look for reviews. Cheers!
