Good way to stop car misting up inside?
Discussion in 'Motoring' started by chippyteaforme, Jan 28, 2014.
  1. chippyteaforme
    chippyteaforme
    Dec 20, 2005
    3,503
    Spalding, Lincolnshire
    +201
    Not sure misting is the right word - more like dripping wet. I work nights and when I set off for work at night, or come back in the morning, there's so much water on the inside of my windows it takes ages to get rid of it all, using both kitchen roll and the heater / air-con combined.
    Surely there's something I could use to suck the moisture out of the car when it's not in use?
    Car only used for short trips to and from work really, which is probably what causes it.
    Ta in advance for any suggestions :)
  2. Axl
    Axl
    Oct 19, 2008
    2,558
    2
    Compton
    +3,595
  3. chippyteaforme
    chippyteaforme
    Dec 20, 2005
    3,503
    +201
    Cheers for that. Seen a few of those (or very similar) bags on eBay, got to be worth a shot :)
  4. DVD-Man
    DVD-Man
    Jul 24, 2004
    8,580
    Ayrshire, Scotland
    +1,932
    Buy a plug in dehumidifier and bung it in the boot when parked up, seems you have a seal away somewhere..
  5. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,305
    Poole
    +11,915
    I got at the pollen filter, it was a solid lump after more than nine years.
  6. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    43,882
    11
    13
    167
    ::1/128
    +17,131
    Longer journeys When I had my Audi surplus and standing still for a bit it was terrible. Now I use it daily on decent journeys the problem has gone away. Also keep the air on on all the time.
  7. bobflunkit
    bobflunkit
    Jan 29, 2008
    1,427
    2
    2
    116
    +726
  8. qwerty321
    qwerty321
    Mar 20, 2009
    8,067
    +1,583
    Have you got any bottles of water or similar that are left inside the car?
    I was having a similar issue and noticed a bottle of water rolling around. Took it out and no more dripping wet!
  9. FZR400RRSP
    FZR400RRSP
    Mar 5, 2007
    32,038
    Aberdeen
    +10,374
    This isn't normal.
    Must be a broken seal or water getting in somewhere.
    Are your carpets wet?
  10. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,797
    Newbury
    +258
    Check the plenum chamber(s), they often get clogged with leaves preventing them from draining. Carpet check is a good call. Would help to know what the make/model of car is too.
  11. IronGiant
    IronGiant
    Jun 7, 2003
    67,603
    +48,413
    I also bought one on the basis of the other thread too. My wife's car has an undiagnosed leak so it gets damp, to the extent water drips out of the overhead courtesy light binnacle :facepalm: I thought this would be an extreme case that the Airdry wouldn't cope with but has cleared up her misting up problem instantly.
  12. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,305
    Poole
    +11,915
    Impressive!
  13. bwfcuk
    bwfcuk
    Mar 15, 2011
    402
    +23
    Try closing all the heater vents, Worked on my VW T5..
  14. depot
    depot
    Dec 10, 2005
    961
    43
    +223
    I also bought one of these after reading about it on the other thread, it has stopped the terrible fogging
    of my windscreen, would recommend one.
  15. Dredj
    Dredj
    Jan 17, 2014
    42
    11
    +5
    I hate a foggy screen, and when my windows are wet, going to get the ThoMar bag.
    Have previously been wiping down the window with a sponge before I set off but typically when my windows are misty it's a short distance I am going and my heaters don't have a chance to get warm so they mist up again fast. I've tried having the window open instead but it doesn't seem to help and just makes me more cold.
  16. G a f f e r
    G a f f e r
    Dec 31, 2003
    3,044
    U.K.
    +672
    Got the ThoMar bag based on these threads and whilst it doesn't keep the whole screen clear, it definitely keeps the area above where you place it clear .....enough so that now I can just get in and drive leaving the peripheries to demist on the way to work :smashin:.
    I need to remember to dry it out once a week (someone on the amazon review suggest putting it in the oven, but I was thinking leaving it in the airing cupboard over a weekend off).
  17. IronGiant
    IronGiant
    Jun 7, 2003
    67,603
    +48,413
  18. Exemplar
    Exemplar
    Apr 4, 2005
    5,124
    3
    Newark On Trent
    +1,474
    Stop having sex with the windows shut?
  19. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,305
    Poole
    +11,915
    But if they're open there is a draught.
  20. Daz1969
    Daz1969
    Dec 27, 2009
    549
    46
    Manchester
    +128
    Which is why i posted it in the other thread - for a tenner they're superb, I think Thomar owe me some commission lol
  21. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,305
    Poole
    +11,915
    Update - changed the pollen filter a week ago and there is virtually no misting up now despite a dew every morning.
    One question though - how does the air get out? Are there vents towards the rear or do you rely on leakage?
