Good value flat cable
Discussion in 'Cables & Switches' started by barongreenback, May 9, 2005.
  1. barongreenback
    barongreenback
    Mar 30, 2005
    980
    +59
    I built my system up with QED Silver micro cable but when I come to redecorate my living room next month I want to run the speaker cable under new flooring. What would you recommend I buy and do I need to replace all my speaker cable or can I just do this for the rears. Thanks.
  2. jon_mendel
    jon_mendel
    Jan 15, 2005
    946
    +9
    What flooring are you getting put in - IIRC, the silver micro cable is pretty thin anyway...
    Jon
  3. barongreenback
    barongreenback
    Mar 30, 2005
    980
    +59
    Probably a thinnish carpet so it may well show through.
  4. jon_mendel
    jon_mendel
    Jan 15, 2005
    946
    +9
    Fair enough - best of luck finding some flat cable.
    Jon
  5. Stuart.Ainslie
    Stuart.Ainslie
    Nov 20, 2004
    127
    16
    Little Clacton, Essex
    QED Quntour Ultra Flat.
    Very very flat, can't be seen under our living room carpet.
  6. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I use what used to be called Ixos 607 which is a very thin flat cable with self adhesive backing to one side which was specifically designed to go under carpets.
    Ixos still make it but it's now called something else.
  7. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
  8. barongreenback
    barongreenback
    Mar 30, 2005
    980
    +59
    Thanks for the recommendations, much appreciated.
