Good testing DVDs?
Discussion in 'Movie Forum' started by pullman, Aug 29, 2003.
  1. pullman
    pullman
    Hi everybody,
    I'm interested in finding DVDs that are good for evaluating my home cinema setup. Can you give me tips of films to use for this and also any hints what to look for when doing the evaluation?
    I know there are a few more 'technical' DVDs for evaluating home cinema systems. If you have any tips about such as well, I would be very grateful.
    Thanks a bunch,
    pullman
  2. Lux
    Lux
    Nov 10, 2002
    759
    Luxembourg
    if you are looking for test discs then check the avia disc or so. I use a testdisc from a french DVDmagazine, but I think the THX optimizer is good as well.
    If you are just looking for films that highlight your setup then just do a search;)
  3. Howard0000
    Howard0000
    Jan 11, 2003
    1,057
    48
    Surrey
    +84
    If you search the forums about this you will find about 200 threads of use. This question is asked like every week!
  4. pullman
    pullman
    Ok thanks a bunch for the quick replies!
    pullman
  5. Garrett
    Garrett
    Apr 21, 2001
    40,260
    2
    167
    The best thief you’ll never see.
    +6,677
    Here are two that you could look at, here and here and if not mentioned I belive Titan EA is good for suround.
  6. Howard0000
    Howard0000
    Jan 11, 2003
    1,057
    48
    Surrey
    +84
    Terminator 2 and Die Another Day are my two outright favourites for testing.
