Good speakers - any ideas ?
Discussion in 'Desktop & Laptop Computers Forum' started by HMHB, Jun 25, 2002.
  1. HMHB
    HMHB
    Nov 11, 2001
    27,283
    Nottinghamshire
    +6,163
    Can anyone advise me on what speakers to buy ? I'm looking for ones that are very good with music and also give surround (with a subwoofer). The surround would be used mainly for games and the odd DVD now and then.
  2. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I presume you mean PC speakers?
    Couple of queries:
    What is your budget?
    What soundcard do you have (i.e. is it a 5.1 output model, or what)?
  3. Guest
    I'd recommend the Videologic ZXR-500 ,5.1 speaker set.
    This has received rave reviews and looks nice.
    Check it out at www.videologic.com
    You can buy them at www.uktv.pc for 64.50 Pounds delivered.This is the cheapest you will get them.
    A bargain at that price.
  4. HMHB
    HMHB
    Nov 11, 2001
    27,283
    Nottinghamshire
    +6,163
    Yes I do mean for PC
    I have a soundblaster live card but may upgrade to the audigy
    budget up to £200.... ish !!
