Good speaker cables really necessary?
Discussion in 'Home Cinema Speakers' started by kenwooder, Dec 21, 2001.
  1. kenwooder
    kenwooder
    I just purchased a kenwood home theatre system. is it really necessary to replace the original speaker cables with better ones, eg. monster cables? Will the audio really sounds better (or much better) with monster cables?
    if yes, should only the front and center speaker cables be replaced or should it includes the surround speaker cables too?
    :confused:
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,629
    United Kingdom
    +2,233
    Some people say speaker cable makes a difference, others say it doesnt.
    Personally, i think its worth replacing the cables your kit came with, for better quality cables but i wouldnt go mad spending a fortune.
    I bought some Chord Carnival cable (about 3 quid a meter) and it did improve the overall sound.
    Some speaker cables are an absolute fortune (hundreds per meter!!) but I wouldnt spend more on the cables than the cost of my system!!
    Others may disagree!!!
    cheers
  3. ij
    ij
    Hi KenWooder,
    Have a look at the thread below
    http://www.avforums.com/frame.html?...s.com/forums/showthread.php?s=&threadid=23358[/url]
    Its good and looong discussion on the matter. Its a fairly contentious subject - mainly because its a matter of personal taste.
    If you cannot get a demo with different cable, try buying some for the front, and centre speakers (normally shorter runs than the rears too)- and seeing if its worth the investment. As always your ears should be a good control over your wallet.
    Aside from the audio changes difference cables (perceived or otherwise) - the thicker the cable, the harder it comes to route round the room. I've got a loads of right angle bends to route my cable round - I'm trying to hide the cable on top of a picture rail.
    And at each corner the cable curls up slightly, and peaks over the rail.
    I did use bell wire when I misjudged the length of cable I needed, and although it was inoffensive - its was very flat sounding. But as Jase says, "Don't spend a fortune".
    Not having tested a whole bunch of different cables, I'd guess at the reason that it is a much disagreed upon subject is that cable quality does suffer more that most AV items from deminishing returns as the price increase. If it made that much difference I think there would me much more consensus on subject.
    Cheers,
    Ian.
  4. Lowrider
    Lowrider
    It does make a big difference, including surrounds, try Cable Talk 3.1, less than 3 pounds a meter, I use it for center and surrounds, it is very good with the mids and highs, not the best with bass, but as the subwoofer handles those anyway...
  5. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    I agree with Lowrider and noticed quite a big difference when I upgraded to Cable Talk 3.1 but I wouldn't spend any more than that.
  6. kenwooder
    kenwooder
    thanks everyone!
    looks like i've to spend a bit of money getting better quality speaker cables afterall... anyway, it's christmas, no harm spending some dough right?
    Merry Christmas and a Happy New Year to all of you.
    :) :p :D
  7. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    I still cant beleive cables are such a confused matter! They make a difference, but the law of diminishing returns means you spend in correlation with the value of the system!
  8. Zone
    Zone
    Jun 24, 2001
    6,775
    Barnsley
    +2,507
  9. stefaan
    stefaan
    sorry ij, can't access your thread anymore
  10. stefaan
    stefaan
    aah - it's back - sorry guys
