Quantcast
Good speaker cable for marantz pm3000 amp and mordaunt bx2 speakers
mal2pool
Hello. Can anyone recommend a decent (not too expensive) speaker cable to hook my marantz pm6003 amp to mordaunt short bx2 speakers?
WOuld any decent cable to...like QED. Thanks.
peritus
Van Damme 2.5mm blue
QED silver Anniversary XT
Chord Carnicval Silverscreen
These are all more than adequate and I wouldn't look above these; the Chord being my first choice but the Van Damme is superb for its price
mal2pool
The marantz amp is good but still not as good as my old hitachi from the 80s which brought out so many more detail in the music. I wonder if the pm7004 would be better.
zorrofox
I own the Marantz PM6004 hooked up to Dali Zensor 1's with Mogami W2921 cable and I think it sounds fantastic. The Mogami's are a loan set and not paid for yet. Not especially cheap and I wouldn't have purposefully gone out to spend as much on cable but it does sound fantastic and night & day better than when I switched in my previous cables (QED Anniversay).
Good luck.
mal2pool
Can anyone tell me how to link the speakers to the amp. I dont want to bi-wire them, infact i dont know how to...I just have one cable running from speaker to amp
zorrofox
Does your speaker have one pair of terminals or two?
mal2pool
Two sets...4 terminals on each speaker....someone told me you just link the cable to one to two terminals as they have a copper band connecting between each terminal
steveledzep
On each speaker, the copper band (jumper) will connect both +ve's and both -ve's together. You then simply connect the speaker cable from your amp to either of the terminals, observing polarity throughout of course. +ve from amp to +ve on speaker (either terminal) and the same for the -ve's. Very important that +ve goes to +ve and -ve to -ve. Won't cause any damage, but won't sound right if you get it wrong.
zorrofox
Bass in particular will be non-existant if you hook it up wrong but you won't cause any actual damage.
mal2pool
sounds a bit boomy....not used with bass ports on speakers.. even with the bungs. Not sure if i like the speakers...will give them a bit longer to get used too
