Good small subwoofer for a music system?
Discussion in 'Subwoofers' started by nathan_silly, Sep 7, 2003.
  1. nathan_silly
    nathan_silly
    Yeah yeah I know; size matters. However I would like to replace the Yamaha YST-SW40 that I bought with a better one. It MUST be the same size as the Yammy (give or take a cm here or there- certainly not as big as a Rel Q100E) - 252 x 320, as it's behind the left speaker in the corner.
    Is it possible? Or asking too much?
    Music speakers are Ruark Etudes; so the subwoofer must be good upto 50hz.
    Or if it's possible- I have enough room behind each speaker- so I could try dual small subwoofers, taking pre-out from the 8000S into each subwoofer.
    Since I don't have the subwoofer loud in a music system SPL output isn't important; mainly being tight, not sloppy or boomy and with a decent crossover (as I'll be sending low-level, full range)
    hmm maybe a MJ Acoustics Reference 100? Or Reference 150, which would just about fit.
    btw, this is nothing to do with my soon to be SVS, as that's only to be used for AV.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Listen to anything in the MJ Acoustics range as they all seem to be be highly rated by the AV and music press. I have only heard the Pro 50 but that is an excellent little sub.
  3. nathan_silly
    nathan_silly
    Did a quick search- the MH 100 is £350 and the 150 is £550.. does anything know of anywhere cheaper?
    I just looked on Creative Audio's site.
  4. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    The BK Electronics XLS200 is £279. :smashin:
    MuFu.
  5. blue73
    blue73
    May 30, 2003
    113
    Manchester, UK
    Nathansilly maybe fancy doin it yer self, hows about IPLacoustics if yer after a little sub that carries some belt AND ya build it yerself. You can finish it any way yer whantin......fablon, veneer, fancy glass....Or are you after a crazy science project to build the most inexspensive sub in the world..............:smashin:
  6. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    IPLacoustics the cheapest sub Kit I can see is £271.50 + £14 P&P Me thinks the BK would be a better bet. Or is it too big Nathan?
    Which Creative Audio are you talking about, not the sound blaster people?????
  7. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    Must be going mad of course it isn’t, that would Creative Labs, sorry Have not woken up yet.
    I’m interested myself in a decent musical sub and had thought about a kit build but cant find anything better value than the XLS200, unless anyone is willing to sell me an ASW675 for under £300.
  8. nathan_silly
    nathan_silly
    Cheers for that Mufu, that BK looks good. Cheaper than the MJ's with a higher powered amp and 10" (rather than 8")
    Pity I don't have room for the Storm (music) and the SVS (AV) as the Storm is probably a better subwoofer than the BK. I'll still keep the Storm; just use it in another room.
  9. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    If you feeling like spending a little more, let us not overlook B&W's ASW675 :)
  10. nathan_silly
    nathan_silly
    Looking at the space where the Yamaha is- looks like I can't replace it, there's not enough room.
    Unless I buy a front projection of some sort and that'll give me more floorspace.
    I'll have to stick to the Yamaha for now.
  11. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    You could always get a Rel Quake :laugh:
  12. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    How about a Rega Vulcan 350mmx280x280 including feet maybe a bit pricey at £675 though .
    Jim
  13. lmccauley
    lmccauley
    Oct 24, 2000
    3,434
    Newcastle
    +272
    Or Groundy's velo SPL1000 - going in the classifieds for £750.
    Cheers,
    Liam
  14. nathan_silly
    nathan_silly
    Nah not looking to spend that much. He's asking too much for it anyway. It's second hand, therefore it's worth 50% of the value :p
    I'll work out if I can squeeze that BK XLS 200. Just about. Might need to put it a hydraulic press though! :)
  15. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    The Zeus Actif 750 fitted with the Poseidon upgrade may be suitable
  16. SystemBlack
    SystemBlack
    how about a £60 eltax sub 10? looks better than a designer coffee table from IKEA and sounds better too.
  17. nathan_silly
    nathan_silly
    No thanks. I'm trying to replace the crappy Yamaha. Why would I want to buy another crap (or worse) sub?
  18. wookie
    wookie
