Good small component cable
Discussion in 'Cables & Switches' started by demostenes, Jun 29, 2005.
  1. demostenes
    demostenes
    Hi all, :hiya:
    I want to connect my A/V via component and hdmi to my (future :D ) wall mounted tv. . . but there's a small problem:
    I installed 2 tubes inside the wall connecting 2 plastic boxes but found out that they are a little small. 1 for Cat5e and speakers (3x1,5 for center and surround) and another (25mm wide :eek:) for hdmi and component.
    Can some1 tell me if there's a good component cable with small connectors and not very wide. I'm thinking of the ixos XHV 704 (photo) is it a good and strong cable :lease:
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,413
    The Borders
    +2,590
    demostenes
    Is the conduit 25mm square?
    HDMI has to be supplied with the connectors attached - whilst a Mini 75 Ohm Multicore (for YUV Component) could be made up on site; assuming you have someone with some soldering skills (or the proper crimp tools).
    Pulling a fully assembled 3RCA cable (no matter how thin) through a 25mm conduit along with an HDMI cable is going to be fun!!!
    Best regards
    Joe
    PS You don't mention Power!!!
  3. demostenes
    demostenes
    Hi Joe thanks for the reply,
    The conduit is 25mm in diameter and 1m long and I'll try this weekend to install the cables to see if it can be done.
    I installed 2 outlets for power and antena (separatelly inside 2 tubes).
    If i knew then what i know now i would install a plastic 80x40mm plastic rectangular conduit like those that run data cables :thumbsdow But i dont want to "destroy" that wall again :eek:
  4. 9761
    9761
    May 16, 2005
    499
    I have those Component leads for sale and they are very thin. Give good picture too
