Good Site for DLP Bulbs
Discussion in 'Projectors, Screens & Video Processors' started by Gadjet, Mar 10, 2005.
  1. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    My bulb gas finally gone after 2 years. My PJ is a NEC HT 1000. Can you direct me to the site with good prices as I know this will cost me a lot of money!
    Thank you for you help,
    Phill
  2. ptek
    ptek
    This is Aussie site for UK Co. "http://www.justlamps.com.au/index.html", sure you will find UK link here, suppliers of projector lamps only, pretty smart site to say the least.
  3. rimibar
    rimibar
    May 17, 2003
    465
    Cambridge
    +10
    Try
    HTML:
    https://www.hotlamps.co.uk/image-av/
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,084
    UK.
    +3,486
  5. Clint C
    Clint C
    Dec 10, 2002
    425
    Wiltshire UK
    +4
    Does anyone still use www.pricejapan.com ? Maybe they'd be worth getting a quote for the lamp?
    Clint.
  6. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    Thanks for the sites. I am not sure of the way the bulb went. When I turned on lamp I could here a click sound from projector. Turned round and no light coming from it. The light never started just did not come on. Is this what happens when a bulb finishes because of hours or would it be more of a fault.
    Worried to spend £250 and bulb go staright away,
    Phill
  7. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,084
    UK.
    +3,486
    Did you get any flashing LEDs?
    The pj should flash it's LEDs in a certain pattern and the meaning can be determined from the manual - there's a specific pattern for lamp failure.
    Have you retried it since it went?
    Gary.
  8. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Bought a bulb for my HS10 from Price Japan a few months ago. Good price and it arrived within a couple of days.
    Rob
  9. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    Hi Gary,
    I have tried since a few times. What happens is the lamp makes normal starting noise without lamp coming on and the light that flashes is the "Status" light. It tries this 3 times and then the "Status" light then goes red.
    I have moved house and cannot find brochure, I should download manual.
    Any idea Gary, the lamp light does not flash at all.
    Much appreciated help before spending few hundred quid,
    Phill
  10. Clint C
    Clint C
    Dec 10, 2002
    425
    Wiltshire UK
    +4
    Gadget
    What colour is the status light that flashes when you first switch on?
    Are any other lights on after the 3 tries? "Power" or "Lamp Indicator" if so what colour?
    Clint.
  11. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    Hi Clint,
    The status light is green while it trys 3 times to start up then straight after the 3rd the status light goes red. The lamp light does not come on.
    Too, lamp out, there seems to be a scratch on silver lining inside bulb but elements ok. . Dont think I used all of hours up for lamp life
    Any ideas what problem is?
    Cheers Phill
  12. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,084
    UK.
    +3,486
    here's the codes for the lights.
  13. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,084
    UK.
    +3,486
    You could always take the lamp out and re-seat it if the above codes point to the lamp or lamp door in any way.
    It's easy to do - one screw allows the lamp door to be removed, and then there are two screws which allow the lamp to be removed. Just pull on the little handle.
    While you're in there, you will see the colour wheel. Use a cotton bud (q-tip) and gently wipe the wheel. You may see some residue come off onto the tip. If you do, gently clean the whole wheel. This residue does build up over time on some DLPs and can reduce light output. Cleaning the wheel will restore some added light if it's a thick build up that's reducing light transfer.
    EDIT.
    Just realised we both posted at the same time, so I didn't see your reply to clint. Have you put the lamp back and tried it again?
    Gary.
  14. Clint C
    Clint C
    Dec 10, 2002
    425
    Wiltshire UK
    +4
    Gadget, Gary's giving excellent advice as usual, I'll leave you in his capable hands.
    Clint.
  15. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    Cheers Gary,
    I took out bulb and replaced. While at the same time with windows open making room cold, it is in a warm room. Still will not light. It does the 3 times every time. Going by the sheet you thankfully sent it says the problem is a power failure. Have not got a clue what that will be. I suppose the pj will have to be sent somewhere now for repair on pwer failure.
    Any ideas where I should send it, dont know any where around here, (Wrexham)
    Cheers Gary
    PS. Did see colour wheel and will clean that today, cheers again
  16. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,084
    UK.
    +3,486
    Hi Gadget,
    Contact NEC direct and if it's less than three years old, they should be able to arrange collection, repair and delivery for you - all free of charge I believe..
    Gary.
  17. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    Great stuff, thanks for all your help and time. Found number on from website, open Monday.
    All the best,
    Phill
  18. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,084
    UK.
    +3,486
