good setup?
Discussion in 'AV Receivers & Amplifiers' started by Randy_Badger, Jun 7, 2005.
  1. Randy_Badger
    Randy_Badger
    i want to get surround sound and was wondering if this would be a good set up
    Marantz SR4400 Black (AV Receiver)
    Mission M7C1I Black (Single Centre)
    Gale 3060 BIPOLAR (Rears)
    Aural Envelope ORBIT 851 Black (Subwoofer)
    all these for about £360
    already have mission 704 for fronts
    are these any good or is there any thing better for around same price
    thanks
  2. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    The speakers setup is a good starter and the amp is a good base unit.
    Also worth considering from other sources are
    Yamaha 450
    Sony 675
    Denon 1705
    You could also try giving Miller brothers a phone call and asking if they have any Sony db2000's Left as they are part of the QS range and for the price Miller had it it is a bargain (usually £400). :D
    I havent heard of the sub but would recommend saving more money and buying a Known brand sub in the £150-£300 region as it will make a significant difference to any cheap boom box .
    Consider Ruark vita 50 I think there are a few owners on this forum and are very happy with them or there bigger brother theVita 100 . Superb value for money.
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    The arrangement you suggest should sound great for the money. Although Dfours suggestions are good they do practically double your outlay with some of those options.
    I would definitely agree with him WRT your choice of sub, it's definitely worth saving up longer and follow his advice. The Velodyne CHT power buy on these forums would also be a good option. :)
  4. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    Not quite Hes looking at paying £169:95 for the sr4400 at Richersounds and my amp suggestions are arround that price. Its only the sub option that blows his budget away but will amke soooo much difference.
    Thx Eviljohn2 I always forget about the velo special offer. :eek:
  5. Randy_Badger
    Randy_Badger
    thanks for ur suggestions
    all the bits i seen where from richersounds
    i think ill get
    as u said these r good setup
    and save a bit for a better sub
    thanks 4 ur advice
  6. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    What are your main interests with the amp Randy? Music or movies?
    I would reaslly suggest you look at the other amps I suggested even though Richersounds dont sell them and you would have to go mail order they are all newer models with more power or flexability and better features than the old marantz.
    In the end its your choise and money.
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    I think the Marantz is an excellent choice, my best mate has one with my old Mission 701 speakers and it sounds and it sounds ace. :smashin:
    There's certainly no harm in checking out the other offerings that are available though. :)
  8. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    Actually just noticed thatSuperfi
    have the Yamaha 450 for £149. even cheaper :thumbsup:
  9. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    gale 3060's are fantastic dont let the posh lot put you off them, just an advance warning! ;)
  10. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    also when you go into richer sounds make sure you know EXACTLY what you want and dont let them change your mind (unless they have good quality ex demo stuff), especially dont let them offload a sony str-de697 on you, i made that mistake!
  11. Randy_Badger
    Randy_Badger
    phoned my local richersounds earlier the only marantz sr4400 they had was open baoxed and didnt know if exdemo or return, so ill cross that off list for now same for the mission centre :rolleyes: have noticed that this is discontinued and v few ppl have it in stock.
    the only thing they had was 1 last gale 3060
    so have to have a rethink i dont mind spending a bit more cash if it makes a big difference and means i wont wanna upgrade in 6 months
    as far as use goes itll be a mix of movies, music and console
  12. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    They have the m7c1i here
    Have a look at the other amps I listed and see if any of them take your fancy
    This page should also be usefull in your quest. :smashin:
  13. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    The Marantz 4400 has been replaced by the 4500 which shouldn't be too hard to find. :)
  14. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    look Here for a price list for marantz av amps inc the sr4400 :D
  15. Randy_Badger
    Randy_Badger
    thanks guys u been a great help :smashin: :thumbsup:
    ill keep u updated
  16. Roam
    Roam
    Keep checking your local richers as they are always getting stock in on a weekly basis or you could ring their stock line to make a request you may get lucky. I have a similar setup (Marantz 4300 with Mission M7C1i/M71i's) and find they match up very well and sound good considering the low price.
    http://ws2.richersounds.com/information.php?cda=static&cst=help_contact
  17. Randy_Badger
    Randy_Badger
    Mission M3DS-DP Graphite Black £122.25 or gale 3060 £80
    Mission M3C1I Graphite Black £91 or M7C1IBLACK £47
    Denon AVR-1905-B £216
    wot do u think of these
  18. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    Go for the M3 series :thumbsup: The denon is also a well regarded amp.
  19. andycdubya
    andycdubya
    Jun 11, 2005
    9
    what is wrong with the sony amp, i was thinking of getting one, maybe not anymore!
  20. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    i can only advise you against it. if you were thinking of getting it from RS, empire have it for £150, for that it might be worth it, but if your budget is around £200 i advise you to get the azur 540r, its in a different league to the sony.
  21. andycdubya
    andycdubya
    Jun 11, 2005
    9
    by budget is actually more like £100, very tight, i was actually looking at the 597, i am trying to find a quality bargain
  22. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Andycdubya, for a good quality bargain you must go second hand. The quality and price of the amps available in the market is second to none - look out for the Denon 180x series along with the entry level Marantz and Yamaha offerings. :)
  23. andycdubya
    andycdubya
    Jun 11, 2005
    9
    where is good for second hand other than ebay?
  24. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    The classifieds here are the best that I know of.
    Also www.hififorsale.com and your local freeads. :)
  25. alphabet
    alphabet
    As you are looking at Richersounds, also have a look at the Cambridge Audio Azur 540R, which is selling at 250 pounds. It is worth every penny!
