Good quality TV Card?
Discussion in 'Desktop & Laptop Computers Forum' started by MrCoopz, Aug 19, 2002.
  1. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
    Does anyone know of a decent Tv card for under £100.
    i have read the threads and come to the conclusion that the Pinnacle Rave tv card isnt that good quality wise.
    so could someone point me in the direction of a good card that works with the DScaler
    thanks
  2. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
    Anyone?
  3. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    There aren't any better cards for less then £100. The next level up would be something like the IDS Falcon which is available for about £180. After that you are talking the $895 H3D card.
    Jeff
  4. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
    What about the WinTV cards are they anygood??
    theres alot Here but i dont know if there suitable as i dont know what im looking for
  5. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I wouldn't say that they are any better than the Rave card. You will get the same noise issues. You will also need to check which are DScaler compatible, some aren't.
  6. MyMateJohn
    MyMateJohn
  7. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
    So would i be able to use this for Sky Digital??
