good quality picture for budget price
Discussion in 'Projectors, Screens & Video Processors' started by thekingbeyond, Oct 28, 2004.
  1. thekingbeyond
    thekingbeyond
    May 24, 2004
    5,687
    oxfordshire
    +348
    I am looking for a projector around £700, iam on a tight budget because i will buy a 42 inch panasonic plasma at the same time,my toshiba 50 inch has become to small but i cant keep that and get a projector. I was impressed with urbant`s shots of his display but his model is a bit ouy of my budjet.So a good quality 80- 100 inch picture what about the Hitachi PJ-LC5 any one use that.
    Recomendations please :thumbsup:
  2. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    how about looking at a 2nd hand AE500
  3. thekingbeyond
    thekingbeyond
    May 24, 2004
    5,687
    oxfordshire
    +348
    How much used,are the bulbs easy cheap to replace?What about throw distance the Hitachi PJ-LC5 does 60 inch at 1.8 mtrs
  4. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    +76
    http://www.projectorcentral.com/projection-calculator.cfm
    shoots about 60" from 1.8meters as well.
    price i cant give you a definate as it would be 2nd hand and depends on the owner. check the classified as ppl seem to be upgrading to the newer AE700.
  5. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,684
    Woking
    +230
    Check out eBay as some traders advertise projectors on their pretty cheap. An Infocus X2 for £749
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=22610&item=5727969003&rd=1&ssPageName=WDVW
    Which is a great projector, suitable for PC and movie use
    a Sanyo Z2 ( superb) for only £799:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=22610&item=5726808798&rd=1
    Another Brand New Z2 for £785:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=22610&item=5727754728&rd=1
    If they are out of your price range, then there are also plenty of secondhand projectors on there too for considerably less. Just be sure the seller has plenty of good feedback!!
