Good Quality Hard Button Remote
Discussion in 'Home Cinema Control & Remote Controls' started by bobbles, Feb 8, 2003.
  1. bobbles
    bobbles
    I currently have a one for all 6 7560
    which is fine, but it can only learn an additional 25 buttons/macros
    which isn't enough. Sky+ alone needs an extra 12 from the pre set buttons
    Can anyone recommend a good quality hard button remote?
    I tried the Pronto but I did not like the LCD screen. I like to have every button to hand so to speak
    I am considering the One for all Kam
  2. Michael Brown
    Michael Brown
    I bought a Sony 900 from Richer sounds for £40. Every button can learn a function or macro. I'm very happy with it - tried everything from a one for all to a Pronto and this was the only one i was really happy with
  3. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    Buy the one for all Kam you won't be dissapointed whilst it does not have every single button ever found on a remote it certainly caters for Sky+ and has more than enough buttons to add functions onto.....I have used it for 5 different devices for the past week and not once touched my old remotes:D
