Good quality centre speaker
Discussion in 'Home Cinema Speakers' started by Mr_Tony, Jul 13, 2005.
  1. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    I need a good quality centre speaker please, it needs to come in beech though as the rest of the set up is beech. I have the Eltax millenium centre speaker at the moment, and its not the best.
  2. Astaroth
    Astaroth
    Jun 22, 2004
    2,283
    63
    London
    +117
    There are many good centres (and available in beech) however it is very important that the centre tonally matches your L & R speakers otherwise no matter how good the 3 speakers are independantly they will not sound very good when put together.
    The easiest way of doing this is to buy the purpose built centre to go with the fronts, if this doesnt exist then generally a centre made by the same company will generally be a close match as most companies "have a sound".
  3. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    oh right okay, do you or anyone know any decent eltax ones then?
