Good quality 10m VGA to VGA ?
Discussion in 'Cables & Switches' started by m0v1em4n, Dec 7, 2004.
  1. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Hi All
    I have got my self a Sim2 Domino 20 :) and would like to connect it to a PC via the VGA connection on the Projector and PC
    Does any one have Any suggestions on a good quality 10m VGA to VGA lead willing to pay around the £100 mark :eek:
    Steve
  2. SamirP
    SamirP
    Apr 28, 2003
    1,232
    South Of The River
    +32
  3. newstuart
    newstuart
    Apr 22, 2004
    1,624
    Northumberland
    +55
    I bought one from cable universe for approx £20 as a tester to see if i could get away with HTPC being in a different room than my plasma. I honestly cant fault it the image in as good as the 1 meter one i was using before !
    for 20 odd pounds try it as they will refund anyway.If needed they also do powered USB extension leads in 5 m lengths for about £12 which you can add up to 5 (25 mtrs) from memory.I needed these for remote operation of the pc.
    hope that helps
  4. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Thank you guys
    was looking at the lindy cable just was sure
    Steve
