Good Projector for Sport (under £1000)
Discussion in 'Projectors, Screens & Video Processors' started by MysteryMan, Jul 5, 2004.
  1. MysteryMan
    MysteryMan
    Nov 18, 2002
    639
    Cheshire
    +33
    I'm looking into the options for showing Sporting Events, sourced from a Sky STB, at our local Tennis Club
    I am looking at 42" Plasma screens, but, also considering the Projector route.
    Are there any obvious candidates around the £1000 mark that would do the job?
    Is the choice of LCD or DLP an easy one to make? i.e. Is one obviously better than the other for watching tennis, football, etc?
    Will room lighting be a factor? It won't be practical to impose a blackout when watching!
    Any opinions welcome! :thumbsup:
  2. AMc
    AMc
    Nov 20, 2000
    7,016
    Near Norwich
    +3,646
    I'd have though that at that price and with those viewing conditions a rear projection TV would be the best price/performance compromise?
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,257
    UK.
    +2,781
    I those conditions you'll probably need something pretty bright (higher lumens), and should use a grey screen to improve apparent contrast and reduce the effects of ambient light. LCD will more likely give you what you want, as they tend to be brighter and cheaper. A 4:3 pj would be the best choice unless Sky broadcasts the events you watch in 16:9
    Gary
  4. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,522
    Kent
    +830
    We installed a handful of BenQ 8120s into pubs for Euro 04. 1800 ANSI lumens cheap and cheerful with sealed optics (for smokey environments) goes for about £1100 inc. If room isn't too bright you can get away with 1500 ANSI - so i'm thinking Infocus X2 at under £850.
    HTH
