good place for cables - any recommends ?
Discussion in 'Cables & Switches' started by Ianch, Mar 31, 2005.
  1. Ianch
    Ianch
    Feb 19, 2005
    34
    I'm mounting my plasma on the wall and intend to 'hide' all the cabling. Because of this I'm going to need cables of approx 4m to run between the screen and my equipment.
    Any recommends re: where and what to buy.
    I'm also assuming that I should use RGB scarts to connect both my Sky box and DVD to the screen - is this correct ?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    You can use RGB scart leads as long as you are using a seperate AV amp for the audio as the audio pins in an RGB scart aren't connected.
    There are several forum sponsors who sell cables and interconnects and each of them will have what you need at a competitive price.
