Good match receiver for B&W CDM 9NT/CDM 1NT
Discussion in 'AV Receivers & Amplifiers' started by fvdbergh, Jun 10, 2003.
  1. fvdbergh
    fvdbergh
    Have a set up of B&W 9NT front ,1NT back. Use is 50/50 movies/music and used up to now old 3802 on loan which I need to return.
    Any recommendation/experience on music/movie quality difference between Denon AVC1SR or Denon 3803 + Arcam A85 or recommendation on alternative set-up is similar price range before I organize listening at my local dealer.
  2. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    How about Rotel RSP1066 plus RMB1075.
    Also listen to Pioneer AX10i, the top of the range Harmon Kardon - if you can put up with the looks - and a combination of a AV reciever with a good integrated amp like the A85 as you mention.
  3. dts_boy
    dts_boy
    Nov 26, 2001
    2,615
    Manchester suburbs...
    +178
    the cdm 9nts need a LOT pf power to work properly. i would suggest a cyrus av8 processor with rotel 1095 power or parasound halo 52 power - the parasound is not quite as bright.
  4. fvdbergh
    fvdbergh
    Will the A85 be enough power for the B&W9NT?
