Good freesat box?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by XSP, Jan 7, 2012.
Tags:
  1. XSP
    XSP
    Nov 1, 2007
    47
    Worldwide
    Hi All can you guys point me in the right direction for a good freesat box?
    with capability to record and rewind etc etc
    Thanks in advance:smashin:
  2. Stiggy
    Stiggy
    Dec 7, 2004
    6,718
    Sandy Heath
    +1,043
    Logicel will be along in a moment to direct you to the freesat.co.uk website with a list of all the PVRs available.
    The Humax is very popular around here.
  3. Saggy
    Saggy
    Jun 6, 2005
    1,087
    Herts
    +88
    Might not be the best but saw a goodman had freesat for £39
  4. Railway
    Railway
    Nov 29, 2009
    721
    43
    +105
    :laugh:
    Very happy with my Humax HDR, others seem to restrictive:
    No padding, no save to USB or network etc.
    Avoid Harvard made models, Goodmans Bush etc.
  5. Saggy
    Saggy
    Jun 6, 2005
    1,087
    Herts
    +88
    But that just a viewer not a recorder.
  6. Pistachio
    Pistachio
    Dec 29, 2011
    726
    UK
    +96
    This is one of the many good humax boxes that it will be worth you checking out. The Hd pic quality is stunning and it also has the same sort of features as sky + (pause, rewind, series link, record two channels) but without any monthly charges that sky would charge.
    These cost a lot more than the goodman boxes, but I think they are worth it.
    http://www.richersounds.com/product/freeview-freesat-pvr/humax/foxsat-hdr500/huma-foxsat-hdr-500g
    John lewis would probably have one if you were interested in a longer guarantee. RS would charge an extra 10% for the same guarantee.
    HTH
  7. reevesy
    reevesy
    Feb 20, 2005
    5,881
    +1,843
    another vote for the humax....my only gripe is organising recorded programs is a bit restrictive for me... other than that great.
    cheers
  8. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    As predicted here is the list of ALL the Freesat PVRs: freesat+ HD TV recorder - freesat.
    There is just one Humax, in two versions, so I don't get the reference to "many good humax boxes".
    It is the name that gets the most mentions on the forum, and most of the mentions are favourable, so I see no reason to doubt that it is a good quality machine.
    The others that get fewer mentions don't get specifically bad mentions, so there's no reason to suggest that they are not of equally good quality.
  9. XSP
    XSP
    Nov 1, 2007
    47
    Worldwide
    Thanks so much guys,
    really helpfull:thumbsup:
  10. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,197
    Redditch
    +4,112
    Can you explain ?. You can create your own folders and move multiple recordings into these. What's missing ? (apart from moving a whole folder into another)
  11. reevesy
    reevesy
    Feb 20, 2005
    5,881
    +1,843
    well in my case i've loads of 'later with jools holland' shows recorded.....some are grouped in different folders and some are on their own
    ...i would like to group them all in one place...ideally one folder
    tried renaming them so they might all regroup together but the humax has just put loads on themes on the same name....eg later_with etc
    not sure if regrouping them in one folder can be done or not?
    cheers.
  12. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,197
    Redditch
    +4,112
    Open File Manager (Media OPT+ File Manager)
    Cursor Right - press blue choose make folder. Create the folder and then click OK to open it.
    Cursor left and open one of the folders you want to copy the contents of into your new one. Press Yellow (edit mode). Set a tick using OK on all the files you want to move. Now Press the move button. Repeat for the other folders in turn. Move to the root folder and enter edit mode, select all the strays and repeat.
  13. JIMMYBO
    JIMMYBO
    Feb 10, 2011
    203
    +24
    Check your local Argos store NOW:
    Humax Foxsat 320GB HD Freesat Digital TV Recorder @ £190 :smashin:
  14. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    But still expensive, imho.
  15. killiedel
    killiedel
    Feb 10, 2007
    4
  16. JIMMYBO
    JIMMYBO
    Feb 10, 2011
    203
    +24
    But there's at least £190 worth (imho) of bundles - HD upgrade/Network connection advice etc all for free and available on this thread thanks to the briliant work of the Humax Foxsat firmware mods (no pun intended) :smashin:
  17. JIMMYBO
    JIMMYBO
    Feb 10, 2011
    203
    +24
    The RS box is just the same hardware/firmware but with a larger HD
    If you're upgrading to 1TB anyway, go for the 320GB from Argos (if you can locate one at a store near you) :rolleyes:
  18. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    Yes, I highly respect their expertise - but still have no idea what it actually does.;)
    I'm sure that whatever it is is very useful to them, but doubt its relevance for Mr Average.
  19. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,197
    Redditch
    +4,112
    Considering the number of postings requesting how to view their box on other TV's I imagine it's very relevant to many Mr Averages :D
    You can watch different recorded content on multiple tv's completely independently of the main user.
    eg
    Dad could be watching the footie live, number one son could be watching a recording of Top Gear in his bedroom and the better half a recording of Corrie in the kitchen all from the one box :D
  20. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    So, that's what all the jargon is about?!:clap:
  21. Retro Oswald
    Retro Oswald
    Oct 20, 2005
    21,236
    Ashford, Kent
    +2,424
    And how would one go about being able to do that?
  22. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    By using the "at least £190 worth (imho) of bundles - HD upgrade/Network connection advice etc all for free and available on this thread thanks to the briliant work of the Humax Foxsat firmware mods" that prompted my question and glt's reply.
  23. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,197
    Redditch
    +4,112
    I think that logi now understands some of the capabilities of the Foxsat-hdr (it took a while :D).
    Raydon and other conrtributors deserve the credit ( Raydon get a job with a pvr maker, the result would be fantastic).
    http://www.avforums.com/forums/free...e-server-bundle-foxsat-hdr-release-4-0-a.html
  24. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    I took a while because until your post #19 nobody said in English what it's for.;)
