Good component cables
L
Le_Duke
Hi there,
this is my first post :clap:, I have a Sanyo Z2 and a Pioneer DV-757Ai, and I need to buy (on-line) good component cables with 9 meter, could you please give me a hand?
Thanx:smashin:
You can get top quality 30' Belden cables from www.bluejeanscable.com for $76. Don't forget you may get stung for import duty and VAT which would add about 25% to the cost. Hope this helps.
Steve
Le-duke,
I've got 10M QED SR-CV1, they are a bit pricey though,
CPC do component cables as well and its much more cheaper.both can be obtained on- line.
Check Mark Grants component cables over in the PowerBuys forum.
Which are made from the identical components that Bluejeanscable use (i.e. Belden cable, Canare connectors, made with Canare crimping tool).
Service from Mark and the quality of the product are superb. I whole-heartedly recommend.
Sony BRAVIA 9 Mini LED TV: The Best HDR TV EVER?
Back
