Good, Bad, or Ugly?
Discussion in 'AV Receivers & Amplifiers' started by Donnie, May 29, 2003.
  1. Donnie
    Donnie
    Your views please..
    Seen a deal at HiFiBitz Pioneer VSX-c110 AV, DV454 Multi-dvd and SV40 speakers for £375. How goods the kit and is it at a good price?
    I apologize for my total ignorance any views appreciated!:clown:
  2. sounddog
    sounddog
    Dec 11, 2002
    3,437
    107
    Leicestershire, UK
    +477
    The DVD is good, the Amp bad and the speakers ugly ... think thats the right order.
    Vikki
    PS ... please don't take this as serious comments on the equipment ... :suicide:
  3. Jimmysil
    Jimmysil
    I think the dvd player is fine, the amp I cannot say.
    But the speakers I am not so sure about.
    I think different speakers would give much better results.
    Are you only interested in a silm system or will you consider a larger amp for example ?
    Regards
    Jimmysil
  4. Sunday Ironfoot
    Sunday Ironfoot
    Thanks for helping me spill my coffee all down my shirt :(
    :smashin:
  5. Jimmysil
    Jimmysil
    :D
  6. sounddog
    sounddog
    Dec 11, 2002
    3,437
    107
    Leicestershire, UK
    +477
    :devil: :p :devil:
    Vikki
  7. 337GUS
    337GUS
    Nov 1, 2000
    751
    NE Scotland
    +38
    Just back from my mates where I was helping to install the VSX-C100 (I assume you mean this model) / DV454 / Infinity Alpha HSC 5.1 package.
    Amp - surprisingly good sound - challenged connectivity wise but as he only has DVD/Sky+ he is happy. Just check in case you may need more inputs in future.
    DVD - Played Blade II and Terminator 2 Region 1 into Philips 28 flat widescreen RGB Scart - superb for the price.
    CD playback - pretty good, much better than his Sony midi system.
    Infinity speaker package - not bad, prefer equivalent missions but these were 60% off and all he wanted to spend.
    SV40 speakers - no idea. Would check out some alternatives if I were you.
    Consider ex-dem/used. Maybe save up and add the speakers in stages, buy fronts, then rears, then centre and finally a sub.
    HTH
    Gus
