Good/Bad DVI/HDMI cables...
Discussion in 'Cables & Switches' started by monotone, Jul 26, 2005.
  1. monotone
    monotone
    Am finally setting up my DVD/Plasma thru DVI/HDMI
    Anyone tested or found much difference in quality between a branded and non branded DVI/HDMI cables...
    Would like to maximise the picture quality of my set up... Was should I lookout for?
    Cheers!
  2. MyBoxLife
    MyBoxLife
    Jun 15, 2005
    2,651
    Birmingham
    +126
    I've read that if you're doing some distance data travelling, Lyndy is the way to go.
  3. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    I have it on good authority direct from a technical guy of a British cable manufacturer who, in a face to face conversation, told me not to waste my money by buying one of his expensive cables and stick with my generic 2m HDMI->DVI cable that I bought on ebay. It would however have been a different story if my requirement was for a longer length.
    -Ian
  4. loadsofleads
    loadsofleads
    As ianh64 says, with longer lengths it really is better to get a good quality cable when it comes to DVI signals. Supra have developed new digital cables which are specifically designed to be used at longer lengths, but they won't be out for 3 to 4 weeks.
  5. monotone
    monotone
    Guess if I need only 2-3m... the 'brandless' cables on ebay are equally good then? :)
  6. loadsofleads
    loadsofleads
    At that length, a generic cable should do a good if not pixel perfect job :smashin:
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,577
    The Borders
    +3,030
    Hello all
    monotone - I'd suggest a shoot out and view a couple of different cables in your system and see for yourself if you can spot any differences.
    Molex vs. BetterCables vs. WireWorld (Starlight5) covers £30 through to £250 (UK SRP's) for a 2m HDMI and can be an interesting test.
    ianh64 - I'd suggest your 'technical' mate should make decent not expensive cables :)
    taffyoyo - if only Supra had got it right first time around!!!
    Best regards
    Joe
  8. loadsofleads
    loadsofleads
    It's taffyboyo pal, I'll get the CEO's Number so you can give him a good talking too :nono:
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,577
    The Borders
    +3,030
    Hello taffyboyo
    Be assured those discussion happened a year ago when it became apparent that there was a problem with the original Supra DVI cables at 12m with anything above 576P.
    Best regards
    Joe
  10. monotone
    monotone
    Hey
    As most of my set up cables r from Audioquest (I'm a believer of Audio cables), and has been really happy them... am tempted to use their HDMI cables too...
    But I'm texted coaxial & toslink cables (Digital) before, and the difference is pretty minimal. So am not too keen to spend twice the price for an Audioquest HDMI.
    Anyone using the Audioquest and are really impressed/disappointed by them?
  11. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    Joe - You may have more clout doing this since you stock their analogue cables ;)
  12. loadsofleads
    loadsofleads
    It taken them a year to get this problem sorted :eek:
  13. dancingmatt
    dancingmatt
    Apr 26, 2005
    433
    +13
    I'm after a 5m DVI-HDMI cable - and just can't justify spending £40+ on it to be honest. It's to go between my PC and my Sanyo Z3 projector, and I'm all for maximising quality and not buying a cheap cable off eBay when I've got good kit to connect, but it's just a lead... yeah, lots of material technology goes in, I know, but still...
    Anyone want to recommend a good deal they've seen on 5m DVi-HDMI cables?
    DM
  14. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,577
    The Borders
    +3,030
    Hello all
    taffyboyo - I guess Jenving (Supra) wanted to ensure they got it right second time around :)
    dancingmatt - a Molex 5m DVI>HDMI works well and should just about fit your budget.
    Best regards
    Joe
  15. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    The Wheldon Road end!
    +8,369
    I'm in exactly the same boat, linking a PC to a Z3 projector. I've found this 5m DVI-HDMI lead here for just under £20 with postage.
    I really can't warrant paying £50 for a cable so hopefully this will do a decent enough job.
  16. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
  17. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    +8,369
