Hi, does anyone know of any really good and reliable video capture program designed for capturing an analogue video signal from an external source such as a VHS recorder to a laptop?. I have been using a number of freeview programs (one a purchased program called Arcsoft which came with the Climax Digital capture device, but each time the tape jumps when played the program immediately displays a recording has stopped message because it wrongly thinks it's a copy protected tape when it isn't). I suspect alot of other similar programs will do the same. All of the other free programmes I've been using such as Debut Capture, VirtualDub etc don't do a very good job at capturing, often the framerate isn't as it should on playback, though during recording it seems fine (and the framerate it set as it should be for a PAL system). On the Arcsoft program which came with the device there is never a problem with framerate or video lag or audio missing during playback except that it throws up the annoying copy protected message everytime a tape jumps. So it can't be an issue with the drivers or the video and tapes I'm using, probably the free stuff I've been using isn't very good.
Depending on which program I use, sometimes a particular tape I'm capturing from the VHS recorder will capture smooth video, but as the tape progresses the video starts to lag and become choppy, this is noticeable when playing back the captured recording; whether this is down to RAM I'm not sure, certainly can't be due to harddrive space. Alot of the time this is probably due to a poorly worn tape, which is understandable given alot of the tapes I have have been worn alot, but when they are played from the recorder to a TV there is no framerate or lagging at all just the usual jumps, tracking issues that are associated with the tape.
I have two laptops (a laptop probably isn't the best for capturing video I suppose), one an Acer running on Windows Vista (over 10 years old but still performs well with video playback even HD video). My newer laptop is a Toshiba Satellite AMD A8 on Windows 8.1 64-bit with 1TB HDD.
If anyone can recommend a very reliable capturing program for capturing external analogue video I would appreciate it.
