Golf GTi MkV tyre choice?
Discussion in 'Motoring' started by AMc, Sep 25, 2017.
Poll closed Oct 2, 2017.
  1. Michelin Pilot Sport 4 - £117.30 each
    2 vote(s)
    66.7%
  2. Michelin Cross Climate - £128.50 each
    1 vote(s)
    33.3%
  3. Pirelli P Zero - £104.99 each
    0 vote(s)
    0.0%
  4. Pirelli P Zero Rosso - £127.50 each
    0 vote(s)
    0.0%
  1. AMc
    AMc
    Nov 20, 2000
    7,379
    Near Norwich
    +4,115
    My '58 plate GTi came with Pirelli P Zero Rosso 225/40 18 all round (IIRC).
    I couldn't find them last time so I fitted Michelin Pilot Sport 3 on the back.
    No complaints about them but nothing to rave about. I don't take the car to the track and I drive briskly but not like a rally driver on the road.
    Last year I fitted Michelin Cross Climate on our Mini in case we got snow as I have an 8 mile cross country school run. The weather in East Anglia was mild and never saw snow, they were fine in the wet and cold though and were a massive ride improvement over the Bridgestone runflats.
    Now I need new fronts again for the GTi and I have a choice.
    Fuel E
    Wet A
    72dB
    Load index 92
    Y speed rated
    225/40Y18 (92)
    Fuel C
    Wet A
    71dB
    Load index 92
    Y speed rated
    225/40Y18 (92)
    Fuel E
    Wet A
    71dB
    Load index 88
    Y speed rated
    225/40Y18 (88)
    Fuel C
    Wet B
    69dB
    Load index 92
    Y speed rated
    225/40Y18 (92)
    I have a sneaky suspicion that I wouldn't tell the difference between any of these but what would you choose and why?
  2. booyaka
    booyaka
    Sep 26, 2002
    10,902
    +3,397
    I think your probably right - 95% of us either couldn't tell the difference or don't care. I've generally always just stuck with Michelin tyres but for no particular reason!
  3. AMc
    AMc
    Nov 20, 2000
    7,379
    Near Norwich
    +4,115
    The Michelin Pilot Sport 4 are my current front runner, mainly because of A rating in the wet and C rating for fuel. Again I'm not sure I'll notice the difference in my pocket from better fuel economy.
    Still curious what anyone else would do.
  4. Aerojon
    Aerojon
    Jan 11, 2009
    539
    46
    +177
    important info missing,load index and speed rating..Not all tyres that sizes have the same load index and speed rating..
  5. AMc
    AMc
    Nov 20, 2000
    7,379
    Near Norwich
    +4,115
    Fair point, I've added them to the first post.
    Looking at the descriptions they're all Y speed rated (186mph) which is well above the top speed of the car even when it was new :)
    The Rosso are lower load rated than the others which seems a bit odd.
    I have 92 Y on the front and back at the moment.
  6. deanym
    deanym
    May 29, 2004
    1,833
    +143
    I used Goodyear f1 assy 2 on a golf r32. 225/40 18. Suited the car very well.
  7. AMc
    AMc
    Nov 20, 2000
    7,379
    Near Norwich
    +4,115
  8. duffbeerdrinker
    duffbeerdrinker
    Nov 24, 2007
    1,400
    116
    +1,155
    Forget the asymmetric 2's - they've been replaced by the better (and cheaper) asymmetric 3's.
  9. AMc
    AMc
    Nov 20, 2000
    7,379
    Near Norwich
    +4,115
    Weird - A2 are £126.76 at Blackcircles
    Goodyear Eagle F1 Asymmetric 3 - £97.26 at Blackcircles plus a £10 off code for buying 2.
    Fuel C
    Wet A
    67dB
    225/40 R18 Y (92)
    I'd almost made my mind up for the Michelin PS4! :rolleyes:
  10. duffbeerdrinker
    duffbeerdrinker
    Nov 24, 2007
    1,400
    116
    +1,155
    I'm going for the asymmetric 3's next time. The michelin ps4 is a great tyre but the Goodyear is cheaper and has less road noise.
  11. deanym
    deanym
    May 29, 2004
    1,833
    +143
    Agreed, it was 2 years since I bought tyres for the golf and since sold it.
  12. Aerojon
    Aerojon
    Jan 11, 2009
    539
    46
    +177
    it's been about 20yrs since I bought any of the mainstream tyre manufactures..Been using falken's/toyo's for the last 12yrs..
  13. AMc
    AMc
    Nov 20, 2000
    7,379
    Near Norwich
    +4,115
    Fitted Michellin Pilot Sport 4 - great service from STS Tyre Pros in Acle as ever. If you're in the East of Norfolk I would recommend them.
    Car is a lot quieter than the worn Pirellis it had on the front but then a new tyre to a 2mm tread isn't a fair comparison. Braking is nice and sharp again and I can't spin up the front wheels in 2nd any more ;) again what else would you expect from a brand new tyre?
    Happy enough with the tyres a bit sad about the state of my wallet but there you go ;)
  14. gibbsy
    gibbsy
    May 17, 2007
    12,378
    3
    Cwm Cynon, De Cymru
    +6,698
    I've just picked up a new GTD. Bridgestone Potensa tyres are fitted. Noisey, or have I been spoilt in the quiet comfort of an Audi Q3.
  15. AMc
    AMc
    Nov 20, 2000
    7,379
    Near Norwich
    +4,115
    https://www.blackcircles.com/catalogue/bridgestone/potenza-s001/225/40/R18/Y/92/f?tyre=30313437
    Rated E for fuel,
    B for wet stopping
    72dB for external noise
    £13 a wheel cheaper than the MPS4 I bought if ordered at Blackcircles (£102.79 vs £115.80)
    1 dB louder - but similar to the Pirelli I had before.
    Hopefully your getting good cornering for that E fuel rating.
    I read online that the noise rating isn't super useful as it's external not internal - I guess internal is so dependent on the cabin soundproofing and suspension that you couldn't objectively measure it across all types and sizes of tyre. External noise can be measured with a cablibrated set up and driving past.
    My suspicion would be the GTD has harder suspension so you're getting a bit more road noise but it's hard to be objective unless you used a sound meter app on your phone or a proper meter.
  16. duffbeerdrinker
    duffbeerdrinker
    Nov 24, 2007
    1,400
    116
    +1,155
    I've got a GTI with the same tyres and I have the same experience with noise. The Bridgestone's wear very slowly but as a consequence they don't have much grip - particularly in the wet.
    The GTI/GTD is not the quietest car inside anyway but the tyres don't help. Your Q3 would have been much quieter.
  17. dts_boy
    dts_boy
    Nov 26, 2001
    2,670
    Manchester suburbs...
    +215
    Just thought I would add to this - have a 2016 GTI PP and just changed the front tyres from Bridgestones to the Michelin PS4's and the change is quite dramatic!
    Did a lot of reading (probably too much!) but settled on the PS4s and a few hundred miles in am thinking I made the right choice, handles a lot better and seems to be a little quieter
  18. AMc
    AMc
    Nov 20, 2000
    7,379
    Near Norwich
    +4,115
    GTi went in for MOT on Monday. I was a bit shocked when I got a call that the rear inside was below the limit, thought I'd checked them quite recently but clearly not :blush:
    So my mechanic offers me Michelin Pilot Sport 4 for £108 each fitted or Pirelli Zero for a bit less but he doesn't rate them.
    Had a really good experience of the Michelin Cross Climates on the Mini during the Beast from the East so I'm keen to get them on the Golf. His supplier can only get them for £140 a wheel :eek:
    I reluctantly agree to PS4.
    Then over lunch I check Blackcircles - £190.42 for a pair delivered to my mechanic on Wednesday. Give him a bell, "fine I'll cancel the order, keep the courtesy car until Wednesday, order them and have them delivered to me". Obviously I'm paying him to fit them and he's happy to put the new tyres on the front wheels. Order placed at 1pm.
    Got a call Tuesday at 9am - Blackcircles have just delivered my tyres, ahead of all his other parts deliveries even from the local suppliers, car will be ready that afternoon :).
    October/November is £290 for tax, an MOT, service and Insurance will be due too but at least I've saved a few bob. Top service from Blackcircles and from my friendly village mechanic :thumbsup:
  19. mikes48
    mikes48
    May 11, 2007
    1,387
    116
    Preston, Lancs
    +1,463
    FZRR.png ;)
  20. AMc
    AMc
    Nov 20, 2000
    7,379
    Near Norwich
    +4,115
    :confused: haven't seen that Avatar for a while :confused:
  21. mikes48
    mikes48
    May 11, 2007
    1,387
    116
    Preston, Lancs
    +1,463
    It still comes in handy once in a while :smashin:.
  22. gordon115
    gordon115
    Oct 24, 2005
    276
    +9
    After a recommendation from my son I fitted Uniroyal Rainsport 3's on my Golf R.
    These tyres are as good as the Bridgestones they replaced in the dry but are fantastic in the wet.
    Only about £75 each too.
  23. un1eash
    un1eash
    Nov 14, 2007
    4,981
    2
    +1,407
    I always recommend Uniroyal Rainsport 3's. Great tyre for the price and the best wet tyre I've ever had.
  24. booyaka
    booyaka
    Sep 26, 2002
    10,902
    +3,397
    Goodyear Eagle F1 Asymmetric 3 getting fitted tomorrow on my Mk7 golf GTI - £92 each including fitting at home so don't even need to leave the driveway.
    Done 17.5k on the tyres from new - backs are fine - plenty of life in them yet.
  25. MooCow
    MooCow
    Sep 14, 2011
    1,453
    116
    Bath, UK
    +539
    Very happy with mine - GTI Mk5, just had them all changed out last week and geo done. Drives like a different car now, replaced a right mishmash of cheapo brands that have been on the car since I bought it. They had plenty of life still in them, but knew that I wasn't getting the best out the car with them.
