What about the Mizuno HMB 4 iron, which is also a hollow body utility iron, and very popular on the Tours. Or the 921 HMP 4 iron. They’re both designed to match your irons as they have almost identical specs including offset, which is more of a big deal than many realise. Obviously you can have the same custom specs as your irons too.
yeah - Looked at that - They both look lovely.
I wanted to "play" with something that has some adjustability to hopefully gap out the bag at that end.
Been playing around in my head with a couple of options.
I was tempted with a 2nd hybrid (my existing 19 is fixed, no adjustments) or a longer iron.
Ideally probably something like:
3 wood 14.5 (this stays in - love it G425 max)
****** Something 17/18
****** Something 21
New 5 iron 24 degrees
That would probably be ideal setup^^^
However to achieve this I would probably need to sell 19 Cobra hybrid as no adjustability, and get another two clubs to fill the gap.
So trying :
3 wood 14.5 (this stays in - love it G425 max) - Can also adjust this up or down 1.5 degrees
Cobra hybrid 19 (existing)
Cobra Utility 21/22 degrees. (new)
Trying the Cobra Utility iron (4) as it's 21-24 degree adjustable to see if I can gap it out better. If not, I can sell it on fairly easy (Paid £169, got 5% off first order and 5% cash back) - so effectively around £150. Selling 2nd hand good on ebay for around £120/30. So no great loss.
Just going to spend winter trying to set the bag up properly for next year.
