Any decent 5W40 oil will do (Castrol, Mobil, even Halfords oil is pretty good)
Saying you need VW oil is there way of making money and getting you to go to them.
Needs to be to their spec ( vw 505 00 vw 505 01 i think) not their oil. It has to be to their spec believe me it does make a diferance and will save you £1000 engine rebuild
Do you know of any of the well known brands that match their spec then?
Cos I will go out and buy some if I think there's any danger of me doing damage.
Look in your manual.
Under oil spec, it will say something like VW 504.00 or VW 505.00 etc.etc.
Then go to the garage/Halfords and look at the back of the bottle.
Provided you see those numbers on the back of the bottle, you're fine.![]()
