Question Goldeneye - can I play it again?
Discussion in 'Nintendo Forums' started by rtrt, Aug 23, 2018.
  1. rtrt
    rtrt
    Nov 26, 2011
    5
    As i read today that its the 21st birthday for the classic that soaked up many hours of my teenage years - I've been reading around trying to find a way to connect my old UK N64 to my not quite as old Dell SP2008WFP monitor.
    I though a SCART to VGA cable might work, but ive not managed to find a confirmed answer either way.
    Or maybe I need one of these - https://www.amazon.co.uk/GANA-Compo...coding=UTF8&psc=1&refRID=3WSMYQ1BY70P02HCSPYF
    Some of the reviews suggest it should be ok, but then it also says this- NOTE: May experience less than three second lag!
    A cable wouldn't cause any lag and simpler is always better - no PSU, electronics to go wrong.
    I can solder, so if cable pins need to be redone thats no problem.
    Any help given would be really great.
  2. rtrt
    rtrt
    Nov 26, 2011
    5
    Should I maybe post this in one of the tech & gadgets sub forums?
  3. cmdrmarc
    cmdrmarc
    Nov 23, 2010
    3,666
    +1,040
    I ordered one of those HMDI converters from ebay for a fiver - will post a review when it arrives :)
  4. rtrt
    rtrt
    Nov 26, 2011
    5
    Thanks vm - look forward to hearing how it goes. Can you share a link pls?
    I think we may have one difference though, HDMI is ok on my monitor but with a HDMI to DVI converter iirc.
    It was a few years back that we connected a PS3 to it. There was no audio though - so we used the optical out on the PS3 to a DAC.
    How will audio work for you?
  5. cmdrmarc
    cmdrmarc
    Nov 23, 2010
    3,666
    +1,040
    Ah I see - audio works fine through HMDI as mine is going to a tv. What you’d need is an audio > 3.5mm adaptor so you could plug the audio into headphones/ a speaker maybe.
    HDMI to 3 RCA CVBS Full HD Video 1080P AV Composite Converter Adapter 711005758772 | eBay
  6. Johnmcl7
    Johnmcl7
    Jul 8, 2005
    4,558
    Invermess
    +1,586
    A cable would only work if the standards are compatible with each other but in this case they aren't so you'll need a converter box which will inevitably add some lag. You will find scart to vga cables for sale but if you check the reviews you'll find they don't actually work.
    John
  7. cmdrmarc
    cmdrmarc
    Nov 23, 2010
    3,666
    +1,040
    Turns out I ordered the wrong way round! This converts HDMI > RCA. Doh! Have ordered this one instead Composite AV CVBS 3RCA to HDMI Video Converter Adapter 720/1080p + HDMI Cable FT | eBay
  8. mikeysthoughts
    mikeysthoughts
    Jun 1, 2018
    507
    63
    Baldock
    +335
    I daresay lag won't be an issue when you see the frame rate of Goldeneye. It was a great game.
  9. cmdrmarc
    cmdrmarc
    Nov 23, 2010
    3,666
    +1,040
    Thoughts here N64 on LED HD TV
    No noticeable lag but I'm not a pro by any stretch of the imagination..
  10. jonathanrace
    jonathanrace
    Nov 7, 2018
    40
    11
    UK
    +10
    Have you looked into this? UltraHDMI – RetroRGB it might be overkill for what you're after but maybe if you had a few more classics you wanted to play then it could justify it :)
