Golden ratio, 1x0,6x1,6
Discussion in 'Home Cinema Speakers' started by Lowrider, Feb 1, 2003.
  1. Lowrider
    Lowrider
    I am buying a condo, signing next week, and it has a "perfect" size living-room, 15´x 24´x 9´
    The same area as my current room, wich sounds great, but the old has the lenght twice the width, although attenuated by two small halls in the back...
    Also, now I have 3 direct neighbours, above, under and behind, and I will only have one above in the new place, but I lose the sea view... :(
    It can only get better, looking forward to move in... :clap:
  2. poda
    poda
    Antonio,
    You lucky so and so;)
    Should sound superb, what is the make up of the floor and walls?
    I'll be very interested to know how you get on.
    Regards
    M
  3. Lowrider
    Lowrider
    The floor is swedish "floating" wood, you know, wood on some insulation... The walls are brick and plaster, with a 10´window behind the speakers, my bass trap... :cool:
    I will be adding sound proofing on the ceiling, because of the poor German that lives upstairs... :rolleyes:
    Do you think I will need TACT or a bass equalization... :nono:
  4. General Skanky
    General Skanky
    Jul 28, 2000
    4,220
    71
    +43
    Why the move? Your old place looked ideal.
  5. Lowrider
    Lowrider
    The view of the sea is beautiful, I doubt I will ever get similar, but it is a pain not to be "allowed" to play loud whenever I feel like it...
    Plus it is rented, I had to wait for the divorce to be official to buy my own home, I had to give-up enough as it was...
    This is how it will look, plus heavy drapes, rugs, and my home made acoustic panels... :rotfl:
    [​IMG]
