Im so confused !!
You think you have found a camera that gets half decent reviews then someone else rips it to bits !
I am looking anywhere upto around £500 but i dont want to spend £500 on a camcorder that i wont see a massive difference over something for £250.
Been looking at the Sony HC models but it seems the only one worth buying is the HC90. I like the PC1000 (3 cmos) but is it worth it and its quite a bit over budget.
I just fell like getting a Sony HC19 or something for a couple of hundred quid and be done with it at the moment!
Please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
