Finally my home cinema project is starting to come together basically squeeze as much as possible into a small mid terrace open plan lounge wish me luck.
next step get the lift mounted and everything boxed in then work out speaker placements.
I will probably be the neighbour from hell, im more concerned about black out blinds for daytime viewing if i go back on shift. It will be a case of lower volumes and inviting neighbours around for beers. speaker are going to be ceiling mounted its all a bit of a compromise
