Going mad please help
Discussion in 'Plasma TVs Forum' started by buzzby, Jan 24, 2005.
  1. buzzby
    buzzby
    Right i have sort of asked this before but here i go anyway.
    I bought a panasonic 42PE30 fro John Lewis for £2500. I was hoping they were going to price match RGB direct @ £2200 but they said no.
    I am trying to find a cheaper shop but am having no luck. I assume that JL will only pricematch a SHOP not an online retailer.
    Someone must know of a shop with or without website that has this plasma cheaper.
    Please help
    Buzz
  2. MPK
    MPK
    Nov 26, 2004
    478
    London
    +8
  3. buzzby
    buzzby
    thx for the fast reply i will give it a try. I was using kelko but all it chucked out was online shops
  4. buzzby
    buzzby
    Right just spoke to JL and they wont match KRISH. They sais they need a shop that has the item on display with a shelf edge price lable.
    AHHHHHH Why is it always so hard
  5. Pieman1972
    Pieman1972
    Jan 6, 2005
    58
    RGB does have a shop and I know others on this forum have had success. If you go to the RGB site it says "Click here for shop price" which normally means a quick phone call to them.........
    HTH............
  6. kevin19470
    kevin19470
    Dec 26, 2004
    49
    Sound and Vision have a SHOP in Farnworth, Bolton BL4. Excellent displays. JL Cheadle will NOT price match S&V on-line, but they should pm the S&V shop which is only about 20 miles away.
    Hope this helps.
    Kev.
