going mad - how to connect dvd video freeview
Discussion in 'Freeview & YouView' started by yossi, Aug 2, 2004.
  1. yossi
    yossi
    i have no idea and i'm just not technical minded. i have a video recorder with 2 scarts a freeview box with one scart and a dvd player with one scart and a telly with just the one scart, how can i link them all together. i bought a box which makes one scart 3 but all i am getting is the dvd on top of the freeview, and just by the way i can only record what's on the telly on that side help help help!!!!!!!!!!!!!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    VCRScart 1 to FreeView BOX VCR scart, FV BOX TV SCART to adapter
    DVD SCART to adapter and adapter to TV, DVD OFF to use FV box
  3. yossi
    yossi
    sorry i don't understand - a bit slower video1 to freeview my frreview has only one scart
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    ah that kanckers it a bit!
    FV>VCR>Adapter>TV
    DVD>adapter
    Not best for Quality a iam afraid and cant watch a DVD while recording but can record, analogue or freeview while watching analogue!
  5. yossi
    yossi
    i'll give it a bash - thanks anyway
  6. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    You can get a good box from argos for about a tenner.It is easy to set up and the switching is easy. You only need to put one scart from the box to the tv everything else plugs into the box . You then select what you want to watch F/view , vcr or dvd(rgb is supported). Or you can record freeview to vcr or dvd to vcr. There are also phono out puts for video and audio
