DeeKay86
- Joined
- Aug 31, 2011
- Messages
- 23
- Reaction score
- 3
- Points
- 53
Never noticed lag with football as you describe.
Good to hear!!
It's overpriced still being a 2018 model. People have been getting the predecessor for as low as £1400. You'll have too wait longer if you want a 2018 model at a reasonable price.Just found this:
Sony 65 inch 4K Ultra HD HDR Smart LED Android TV YouView
Its the Sony KD65XF9005BU - £2184 from Richer Sounds with a 6 year warranty and a free sound bar!
Thoughts?
additional note:
Has Dolby Vision, HDR10 and HLG. Also seems to have Full Array Local Dimming!
The Q7 at £1800 isn't good value either I'm afraid. Looks like you're trying to buy at the wrong time, unfortunately. My advice would be to be patient and wait for the right deal to come along rather than to pay more, for less.
As for the stutter in football on lcds you rely on motion enhancements to clear this up if you aren't happy with how it looks out of the box. Luckily the TVs you're looking at all have 120hz panels and ample controls in this department. Don't expect an LCD to perform well in this respect without using them though, you may be happy without changing motion settings but many people aren't.
......not to mention cheap-shot Samsung marketing tactics.....
Have you isolated the issue to Sky Q? If 4K via other sources is fine then try a different hdmi cable - if not solved then speak to Sky. They’ll probably ask you to try a different cable anyway!
This is presuming there’s no updates for either the box or the tv.
One other thing - have you got the hdmi port set to receive uhd colour?
Best of luck with your new set.
Martin.
@DeeKay86 glad you are generally happy with the new TV. The bug you speak of is probably best discussed in the owners thread but its not the same bug that is talked about with the Samsung Q9FN here is it?
The reason I ask is because the bug explicitly affects 50hz content, although I am not sure if its the same on the 2017 models compared to the 2018 ones.
If it is, you should try turning off dark frame insertion in the motion settings, can't remember what Samsung call it but it will be something like "clear motion". You may also just want to test with Auto Motion plus completely disabled.
Btw, the video author, Vincent for certain has Sky also and notices these bugs.
Good to know - will avoid 4K movies on Sky, especially ones I have to pay for. I was going to watch Black Panther tomorrow!
