going directly to black with an LCD projector
foolingreens
I apologize for what may seem like a simple question but I am very new to this forum and looking for a solution for our theatre group.
An upcoming play will have brief sequences of images played between scenes. We had hoped to use an LCD projector but there does not seem to be any way to go directly from our images to black without an intermediate blue screen or shut down sequence. We then have to be able to start up instantly for the next montage.
Does anyone know of a projector that would allow us to do so or another work around that would accomplish the same thing?
Thanks in advance
Andy
Crustyloafer
The Panasonic PT-AE3000 has a blanking function which effectively disables any incoming video signals and displays a blank screen. You also have the choice whether the blank screen is blue or black. This blanking function can be operated with a single button press.
Now, obviously, when the blanking function is being used, the projector lamp is still powered on and as such the black blanking screen will never be perefectly pitch black. The Panasonic is one of the best projectors at its price point for black levels. You are unlikely to notice that the black blanking screen is not perfectly black unless you are operating it in completely pitch black conditions.
LV426
Administrator
Staff member
If you have physical access to the projector during the performance then you could simply place something opaque - a piece of card, for example, between the lens and screen.....
Chox1988
most pj's will allow you to choose the colour of the blank no input screen, be it blue or black- have you tried going through the menu to see if you have this option, as you said you had hoped to use an lcd projector i assume you had one up and were using it until the problem kicked in.
