Godzilla vs. Kong 4K Blu-ray Review & Comments
geogan
Wondering if the HDR metadata is correct as it's only few notches above Skull Island which I thought had lacklustre HDR and was only a subtle improvement over the Blu-ray.
Debunks the beliefs of high bit who*es as VT says...
Godzilla: 2014
Maximum Content Light Level : 498 cd/m2
Maximum Frame-Average Light Level : 92 cd/m2
Kong: Skull Island
Maximum Content Light Level : 456 cd/m2
Maximum Frame-Average Light Level : 151 cd/m2
Godzilla: KOTM
Maximum Content Light Level : 1998 cd/m2
Maximum Frame-Average Light Level : 414 cd/m2
Code:
General
File size                                : 44.3 GiB
Duration                                 : 1 h 53 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 56.0 Mb/s
Movie name                               : Godzilla vs. Kong
Video
ID in the original source medium         : 4113 (0x1011)
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main [email protected]@High
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 51.9 Mb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.261
Stream size                              : 41.0 GiB (93%)
Language                                 : English
Default                                  : No
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 598 cd/m2
Maximum Frame-Average Light Level        : 273 cd/m2
Original source medium                   : Blu-ray
Audio #1
ID in the original source medium         : 4352 (0x1100)
Format                                   : MLP FBA 16-ch
Format/Info                              : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name                          : Dolby TrueHD with Dolby Atmos
Codec ID                                 : A_TRUEHD
Bit rate mode                            : Variable
Bit rate                                 : 3 455 kb/s
Maximum bit rate                         : 5 742 kb/s
Channel(s)                               : 8 channels
Channel layout                           : L R C LFE Ls Rs Lb Rb
Sampling rate                            : 48.0 kHz
Frame rate                               : 1 200.000 FPS (40 SPF)
Bit depth                                : 24 bits
Compression mode                         : Lossless
Stream size                              : 2.73 GiB (6%)
Title                                    : Surround 7.1
Language                                 : English
Default                                  : Yes
Forced                                   : No
Number of dynamic objects                : 11
Bed channel count                        : 1 channel
Bed channel configuration                : LFE
Audio #2
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Commercial name                          : Dolby Digital
Format settings                          : Dolby Surround EX
Codec ID                                 : A_AC3
Bit rate mode                            : Constant
Bit rate                                 : 448 kb/s
Channel(s)                               : 6 channels
Frame rate                               : 31.250 FPS (1536 SPF)
Compression mode                         : Lossy
Stream size                              : 363 MiB (1%)
Title                                    : Surround 5.1
Language                                 : English
Service kind                             : Complete Main
Default                                  : No
Forced                                   : No
Audio #3
ID in the original source medium         : 4367 (0x110F)
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 192 kb/s
Channel(s)                               : 2 channels
Stream size                              : 155 MiB (0%)
Title                                    : Stereo
Language                                 : English
Default                                  : No
Forced                                   : No
Text
ID in the original source medium         : 4768 (0x12A0)
Format                                   : PGS
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Duration                                 : 1 h 45 min
Bit rate                                 : 31.2 kb/s
Count of elements                        : 2706
Stream size                              : 23.6 MiB (0%)
Language                                 : English
Default                                  : No
Forced                                   : No
Menu
00:00:00.000                             : en:Chapter 01
00:09:51.215                             : en:Chapter 02
00:20:07.331                             : en:Chapter 03
00:29:02.323                             : en:Chapter 04
00:38:39.734                             : en:Chapter 05
00:49:15.994                             : en:Chapter 06
00:57:16.850                             : en:Chapter 07
01:09:07.643                             : en:Chapter 08
01:18:33.709                             : en:Chapter 09
01:30:06.109                             : en:Chapter 10
01:41:58.821                             : en:Chapter 11
Only about 600nits again if the actual metadata is correct... not full HDR again... not exactly hard to render some CGI scenes to 1-2k peak highlights. Would like HDTVTest to put this movie through his True/Fake HDR review process on the Sony reference monitor.
Seriously though, when I see some of the moronic comments here about not caring about "graphs and specs" is it any wonder why we are constantly shafted by movie studios, when they can get away with it, given how people proudly proclaim their ignorance online these days.
stigdu
I'm a moron. And proud of it.
lgans316
Only about 600nits again if the actual metadata is correct... not exactly full HDR again is it... not exactly hard to render some CGI scenes to 1-2k peak highlights. Would like HDTVTest to put this movie through his True/Fake HDR review process on the Sony reference monitor.
It is still HDR but not the eyeballs melting type. What I was trying to convey is you can get impactful HDR picture at well under 1000 nits and > 400 nits. Many are hung up on peak brightness and this is one of the film that proves that don't need light cannon HDR grading to melt your eyeballs lol.
Btw, I hope the HDR metadata posted above is correct as the player can sometime show different values.
Greg Hook
Moderator & Reviewer
Last few posts deleted, lets not go back to that crap thanks.
shodan
I'm not saying this movie was bad, but I've actually already forgotten most of it! Like a type of PTSD, my brain has blocked it out from my memory... So the question is, do I put myself through that again to see if its better the second time around, or do I let sleeping dogs lie.. I also do not remember King Of Monsters either....
But I'm sure the disc looks nice....
geogan
Actually I didn't buy the 4K version of this... only got the Bluray version before I saw this review since it also has Dolby Atmos which is what I wanted and though it was just going to be another 2K upscale on 4K disc so not much extra for a huge price increase (€20 vs €35 in shop here).
But now I see it is actually a true 4K DI, I'm thinking I actually do want the full 4K version of it... I wish it was the first time I have bought both Bluray and 4K version of a movie.
Also if anyone is wondering where they got the head of King Ghidorah in this movie... watch past end credits of previous King of Monsters movie to see the small extra scene explaining how.
lgans316
I don't care if it's a 2K DI or a 2K upscale. You still get full resolution of 2K as opposed to 1920x1080 and HDR/WCG to spice things up. There are many 2K upscale that look better than native 4K pipeline. Different movies are shot on different cameras / film stocks applying various techniques and artistic intent which are going to impact overall final output.
mb3195
Have a read of this.
Thread 'The ultimate AV demo disc'
geogan
Interesting. I was thinking it might be. Since it has everything including true 4K DI. And I can see from your equipment list that you definitely have the gear to truly see and hear it properly! I mean I don't even have a HDR or 4K capable PJ yet. And I suppose the relatively low 600nit peak highlights are still far above what even best HDR PJs are able to display anyway. I guess I will be upgrading to 4K disc of this some time and adding to PLEX server.
Oh lets not start the old 2K vs 1080 DI debate again! Personally I don't think 2048x1080 vs 1920x1080 makes much difference compared to 4096 x 2160. Only the extra HDR+WCG makes most difference.
Yes lots of upscales look great and I have lots... also obviously cameras used affects it... but still having shot on a 6K camera and then downscaled to 2K and then upscaled back to 4K is going to be worse than downscaling directly from 6K to 4K... and no amount of marketing and propaganda from industry will convince me otherwise.
mckee74
I can draw you a graph regards pretension if you like?
Garrett
Mod comment to below posters.
Not nice to call members who disagree with you.
Nor is that having a personal pop at geogan.
Coulson
Having watched the 3D version, the colours, contrast ratio and level of detail looks pretty amazing, especially for an SDR picture. But I think that maybe watching on a larger screen helps, especially for detail.
But the 4k DV disc is pretty special. Unlike Blade Runner 2049, the difference between the HDR and SDR presentations is clear. Even at 600 nits, the extra contrast, subtle variation in colours and detail is obvious even on a standard sized TV.
amita
Finally watched this, in great anticipation…
What a disappointment. Dreadful movie. Barely better than Godzilla King of the Monsters, and not a patch on the excellent Kong:Skull Island.
Tim2049
They're all basically sh*t, it's all about the eye candy. Hence Kong vs Godzilla is arguably the best of the bunch...
domtheone
Totally agree. This and KOTM are pure eye candy movies with human characters that are a total waste of time.
In comparison, the Skull Island cast are marvellous and make the movie. Which is light years ahead of the other 2.
amita
Spot on - my wife and I watched Skull Island in awe, totally unprepared for the intensity and gore of it. And that only mattered because it had a great cast and characters.
rustyk21
Completely agree. Don't get the love that skull Island gets, the plot makes about as much sense as this (i.e. None) and all the characters are stereotypes.
If you don't watch this on a big screen you're wasting your time.
Jase
Certainly a full on Atmos mix. Very good in terms of effects placement but someone must have been twiddling the volume knob in mastering as it's loud as hell.
Good couple of hours of brain switched off action for a Sunday afternoon. :cool:
