Glue for plastic?
Discussion in 'Home Cinema Building DIY' started by kev3, Jun 3, 2004.
  1. kev3
    kev3
    Mar 3, 2003
    73
    I'm trying to glue a couple of pieces of plastic together, tried super glue, but that didn't have any effect on it. Does any1 know what i should be using?
    Thanks.
  2. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Loctite 406 is superglue specially developed for glueing plastic but it depends what type.
    What are the plastic parts? I may be able to recommend another method.
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    What sort of plastic? Is it smooth and/or glossy?
    For polystyrene based stuff you want polystyrene cement, this melts the plastic where it's applied so you effectively weld the parts together. I think there are other forms of this for different plastics.
    Alternative Aruldite usually gives fairly good results on most surfaces :smashin:
  4. kev3
    kev3
    Mar 3, 2003
    73
    Its quite a rigid about 1mm thick, its got a slightly textured surface with a matt like finish. Hope this helps, but will definitely check out your suggestions.
    Thanks.
  5. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    I think know the stuff you mean . :) I would try one of the two pack epoxy resins such as Araldite (Eviljohn :thumbsup: ) applied thinly.
  6. mherrin
    mherrin
    Try solvent weld for waste pipes. It's used in plumbing. You should be able to get it at all DIY stores / plumbers merchants.
    Comes in a fairly big tub (about 200ml), so is cheaper to buy than from model shops. There's usually an applicator brush in the lid.
    Hope this is useful.
